86 head question
  • Thread starter Thread starter 302-66
  • Start date Start date Jan 20, 2008
302-66
574
Waco, Tx.
Jan 20, 2008
  • Jan 20, 2008
I just bought me an 86 gt with the 302 ho, it has bbk headers and full exaust and an e cam (doesnt hit) but my question is what would need to be done to change to the 87-up heads? what other mods can be done to this engine to up the hp and tq? How had is it to change to maf?
Thanks
302-66
865.0HO
65
Goldendale, WA
Jan 20, 2008
  • Jan 20, 2008
Some people have been able to bolt on E7's without any problems, others have to notch the pistons. TrickFlows are said to bolt on without any problems as long as the cam stays stock or mild.
If the 86 is stock, it's speed density. MAF didn't hit Mustang until 89', or 88' if it's a California car.
Heads and intake would wake the car up quite a bit. Be careful with the cam though, unless/until the swap to MAF is made.
9
93mustank
  • Jan 20, 2008
Did the swap on my 86....
E7 heads and 89 intake ..... i gained 3 mph in the 1/4 ...easy swap.... enough p/v clearance .... Adding a cam with e7's is a different story
Also did a mass air swap.... Took one hour.... used a maf 89 computer and mass air meter.... just used my own wire
plenty guides online for the swap
86foureye
40
chandler
Jan 21, 2008
  • Jan 21, 2008
e7's and e cam on 86 motor is ok that is what is done on my car but if you go with and more lift than 520 you will hit the pistons due to no valve releif the car runs 12.02 on a 125 shoot
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
