Wheels-Tires 87 8.8 To 02 8.8 Swap And 95 Fronts
Madmardigan
29
I think the 02 axle is about 1" wider than the 1987.
What tire / wheel size / offset should I roll?
Also swapping the front to a 95 spindle, I don't know how much difference there is of if I even need to worry about it.
Are you swapping the entire axle with the disk brakes? If so, that axle is 1.25" wider EACH side...so 2.5" wider overall. Also, the axle mounting points are a different size bolt than the 86-98 axle. They went from 12mm bolts in 86-98 to 14mm bolts in 1999, so this needs to be addressed as well.
If offset isa concern, keep your original axle, swap the disk brakes over to it, and run 94-98 axle shafts
Ok, I was mistaken on the width difference. It's a 31 spline, but all considering Imel going to swap it in.
Was hoping to grab a set of wheels off a SN95 GT to use, but with the offset, I don't want to have to do body work to fit them.
