So, first off, someone did not think of thermostat replacement when they decided how the thermostat housing should bolt to the engine. That lower t-stat bolt is the most effin stupid thing I've seen thus far on this car. I'm not a tech and this is my first big project car but wow, WTF? A slight change to the casting for the water pump would have made this a simple task.
Obviously there's a trick to this thermostat replacement. I notice there aren't any videos for this and it seems LMR (and others) have videos for everything. If you've got a method, I'd love to hear it.
Because while while I was trying to screw the t-stat housing back on, I mangled the threads in the lower bolt hole. They aren't totally gone, but might as well be. No bolt will go in without binding and that's without trying to put the housing on at the same time. Tips, suggestions, etc. are appreciated on how to fix this bolt hole problem. Re-tap the threads?
Thanks in advance.
Thanks in advance.
