8psi boost
  • Thread starter Thread starter 873Stang
  • Start date Start date Jul 23, 2007
873Stang
221
riverside
Jul 23, 2007
  • Jul 23, 2007
stock 302 looking at twing turbo kits, each turbo is set to 8psi, would a stock motor be ok with that? also would i need to upgrade fuel system
millhouse
1,985
Simpsonville, SC
Jul 24, 2007
  • Jul 24, 2007
The stock motor would probably be fine…assuming you don't currently have to much blowby. Lifting the heads is a common issue with the stock head/headbolts too…but it's not typically experienced until a couple more psi of boost.
As far as the fuel system goes…your going to need a 255 h/p in tank pump along with some 42lb injectors and matching MAF. You could go with a lightning MAF but it will require a tune before you can drive it at all. If you keep the boost level's at 8psi or lower it's possible to "get away" with using a fmu and the stock 19lb injectors…but most certainly won't recommend it.
If you haven't found it already, www.turbomustangs.com will be a godsend for all of your questions. Be sure to hit up the "knowledge base" area for ton's of info and FAQ's.
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
D
08 Turbo kit. Who made this???
  • Don7Up
  • Oct 3, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 10, 2026
highplace11
H
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
