93 2.3L stalls when going up hills or 55mph?
lxstang1993
I just got this car 2 weeks ago and it runs like crap.When i pull out of my driveway i have a small hill to go up and when it shifts into 2nd gear it wants to stall so i have to just coast till i get to the top of the hill then it speeds back up and runs fine.But when i got on the interstate and got up to around 55mph it lost all power and i had it to the floor i almost had to pull over then it picked up speed again and the only thing i could think it would be is the maf sensor so i was going to buy one but i need some other opinions on this am i right or is it something else?
could be a number of things. check to make sure you don't have a leak or crack in the air tube from the MAF to the throttle body.
Ide air control valve could be sticking.
EGR valve could be stuck open.
The DIS can be ging bad.
Also could be a bad computer.
While I know MAF's can go bad - it's usually not the 1st thing to go out on the 2.3. Usually running issues with 91-93 2.3's seem to be related to coil packs, DIS going bad, Idle Air crapping out, or computer itself.
easiest things to check are the coil packs - unplug one and see if it runs then the other to verify that they are firing. clean te IAC and I would persoanlly block of the EGR. then move on to more expensive things.
I suspect if the DIS or the computer is original - you might be due for a new one.
I will check out what you said as soon as i get home from work but how much does the new computer cost? im on a low budjet right now and dont want to have to sell my house to get this thing running and i doubt any real maintence was done on this car everything looks original under the hood the odom reads 74,000 miles but it shure dont run like it the maf sensor is cracked on top of the black box part and they had put duct tape over it so i dont know what to do other than replace stuff im not a mechanic and know very little about working on cars so im kinda in the blind but i dont want to take it to a shop and pay out the ass for labor and it has no cat on it just put a new stock muffler on this weekend
new computers are expensive - your best bet is to locate oe in a junkyard.
The black box is actually the air cleaner housing and the MAF is connected to it - it's the aluminum piece that has a small plastic sending unit bolted to it. It has a 3 wire connection. the tube that runs to the engine is bolted to it. The duct tape may just be sealing the air box so that the air that enters the MAF is filtered. That plastic can be fixed better with the PVC cement you can get at the Home Depot plumbing area. Double check the box and the tube to see if there are obvious cracks in it.
if your MAF is cracked on the top - that might be your problem. They will want to sell you the whole body for the MAF but you really only need the plastic part that is held in by 2 security screws. If you have a local u-pull it junkyard, you can get security bits at any autozone tool section and you can go to the junkyard and locate a decent looking 2.3 mustang or ford ranger from the 90's and "acquire" the plastic piece, they fit handy in your pocket. New MAF's is not cheap....
check on their prices for the computer and the DIS and coil packs. Mid 90's Ford rangers ar good sources for the DIS and coil packs - the local yard here charges 20 bucks for a coil pack an has a 30 day guarantee, and 15 for the DIS and 20 for a computer. New, I believe the all are near 100 or more.
Since you mentioned no cats - we can rule out the exhaust being blocked.
another thing to do (and should be done time to time) is to kill the computer's memory by unplugging the battery for atleast 5-10 minutes. It'll reset the computer and the computer will re-learn all it's settings. It'll idle crappy for about a day (or in most cases less) while it re-learns - but clears up and helps. Usually the engine will feel like it's about to stall and then idle will rev up and down the 1st 10 minutes, but that is normal. If it continually stalls I would look at the IAC. This device is what the computer controls the idle - they do gum up and eventually crap out. it's located on the throttle body near where the hose from the MAF hooks up. It's on the back side of the throttle body and is held on by two 8 mm bolts. it has a two wire connector that plugs in on the passenger side of the engine. Many times you can unbolt this thing, clean out the two ports with carb cleaner and it's good to go for a while.
Does it run bad at idle if so above advice is great. Doubt it is computer they are usually pretty bullet proof. Run the codes. How to run codes. The easy no expense way.
http://fordfuelinjection.com/?p=13 Let us know what codes are showing.
Or does it act like when giving gas is running out of gas? If so check fuel pressure 39psi with vac line off. It could be something as simple as a bad fuel filter.
Also does the tach read half of what should be? Possible bad coil pack. Maurice
