Engine 93 5.0 Car Won't Start, Oil On All Spark Plugs!!
Tyler Hunter
20
Hello All, I have a 93 5.0 Mustang that has a stock motor at 185k miles that was running great until recently. It all started when I found out I had an exhaust leak somewhere, I noticed the car had a slight loss of power which makes sense but over time it seemed to get a lot worse. The car would act up while driving and misfire and just seemed sluggish especially when leaving a light. I parked it one day and went to start it a couple days later and it wouldn't start but would crank over like it wanted to. I can hear the fuel pump still prime before I try to start so I know its not dead. After a few tries of turning over it cranked up but only ran a few seconds. it would continually do this running at the longest of about 30 seconds. Then other times it won't start at all. The first thing I did was research some threads and tried a few things. I thought possibly the fuel filter could be clogged so I replaced it and added some sea foam to the gas. Then replaced the fuel regulator and checked the cap and rotor (looked good but I cleaned contacts anyways). Got to the spark plugs and pulled all 8 of them and they were all jet black covered in what looked like to me was oil but could possibly be fuel. I cleaned them all and tried to start it up and still cranks and acts like it wants to start but won't stay running. I haven't yet tested voltage on the fuel pump or ran compression tests. I have a fuel pressure gauge on the fuel rail that is always between 35-40 when engine is running and when just key is on. I did pull the codes but all I got was some EGR codes which has always been there since I deleted the EGR. I absolutely hate taking my car to shops if I don't have too but it sounds to me it could be piston rings or valves leaking. I guess I'm trying to avoid the inevitable but any comments/suggestions/ advice would be appreciated.
Plugs are cheap, change them, no need for irrideum 3g triple threat over priced space age stuff, just some good old motorcraft or autolite replacements. Plug wires are a good idea too, no need to take it to a shop for a good old fashioned tune up.
I say this since you didn't mention any smoking tailpipes.
I agree on the plugs, usually use basic copper autolites or motorcraft. I didn't mention this but when the car would randomly decide to start it would smoke coming from exhaust. Hard to tell if it was blue or white though. I wondered if it was just fuel built up in the cylinder and maybe it wasn't oil on the plugs but instead a mixture of fuel and carbon
When it won't start, do the checklist...
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 15-Sep-2014 to add temporarily bypassing the MSD box if it is present.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD, Crane, or other ignition box if present - Bypass it and return to stock configuration if possible. Do this as a temporary measure to eliminate it as a possible problem source.
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
94-95 models only: Check inside fuse panel for fuse #18 blown – 20 amp [fuse
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it, if you get this far. If it starts, replace the ECT.
Okay so far I have spark all the way through. I ran some tests on the fuel system by jumping the EEC connector forcing the pump to run. I looked at the the pressure gauge and it fluctuates between 38-41 while it priming. When it is not priming by the key is in the "run" position it starts at 40psi but slowly creeps down. I checked the battery and it sits at 12.05 volts. while the EEC is jumped, I'm showing 11.31v on the red wire, 11.22v on the pink/black wire, and 11.19v on the green/yellow wire. When not jumped by key in "run" position, red is at 11.63 volts and pink/black is at 11.65v. When I checked the inertia switch I'm showing .02v in and out. When I check the fuel pump wires in the trunk, the brown/pink is 10.51v which from what I seen is the power to the fuel pump. Are these numbers considered low? When I did jump the EEC connector I heard the relays with click and I have power going in and out. Like I mentioned earlier I started the car and it ran for a couple minutes then drop below 1k rpms and sputtered and shut off. I started it and it ran for a second and shut off then would start anymore after that. It just seems like its getting starved of fuel somehow
I would trydoing a compression test an see if there is a leak in the head gasket or bad rings an it could be ur valve guides are seeping in the cylinder
I would say they are low, charge battery, check grounds and check those volts again.
If you have oil on ur spark plugs its not an electrical problem its mechanical something is letting oil in the cylinder i suggest to find out were the oil is comeing from if you are sure it is oil. An let me know what you find out
So today I replaced the fuel pump because it was the original one to see if maybe that was the problem. Car did the same. Talked to a local mechanic shop and they said sounds like the ICM. Took it off and had it tested at autozone 3 times to make sure and it was good and it was. I'm all out of ideas at this point but now I do believe it is something computer related. I thinking I'm gonna bite the bullet and take it somewhere
+1 on this
At 12.05 volts that battery is very dead. I would also recommend cleaning up all the positive electrical and ground connections. Especially the ground on the fender near your battery for the computer and the connections on the starter solenoid that powers pretty much everything.
I have not run a compression test because I don't believe that has anything to do with the issue. The car ran fine before hand so I don't feel it would all of a sudden have compression issues. I'm gonna charge up the battery tomorrow and clean the connections although they look clean. I was doing some reading on forums and the TPS sensor seems like it could be an issue relating to my problems so I'm gonna check that too.
