Ok. I retuned the ve table for idle. Went for a drive while dataloging. Ran ve analyze only a couple was off 2, rest was 1 or less, so I didn't change anything there.
Now to the hot start. Starts up fine. Runs fine while ASE is on cause I extended the taper on the last block to last longer. When that's over (about a minute or so) it'll run lean at 14.7 (I have it set at 13.7 @ idle) slowly tapering down to 13.7 after about 2 minutes after ASE is over. Much better.
But why does it still run lean for a little while? And slowly taper down even though the MAT doesn't seem to change much?
Now to see if the ve table is still ok when cold.....
I should add that before I did this MAT/ CLT the afr did not come down till I drove it. Now it will after 2 minutues.
