Shakerhood
20+ Year Stangneter
04sleeper said:Looks very good!![]()
I like to see people just make things work.
BTW: Did you ever get that TB fixed?
95opal said:the easy way is to cut the flange off the maf with a hacksaw and use your exsisting cold air kit. No seaching or fabricating the imaginary adapter. Ive don this to three different cars no problems w/ any of them.
Shakerhood said:Does the Fox car run any better with the 94/95 Meter?
JBeezy53 said:Why did you switch to the 94/95 meter?
jrichker said:A trip to the welding shop with the explorer TB and the arm from your old Mustang TB would probably accomplish the same thing.
Less air restriction, same base map equals "more HP". How much? Maybe ~3-5 HP on a stock engine. MAF's are restrictions to air flow. So are the air filter and tubes leading up to the TB. Any reduction in restriction reduces power loss - which means "more free HP". That's why on the new cars, you see big @ss MAFs and low restriction tubes. For very little money, there's no increase in smog, but and increase in HP and gas mileage. When a car company is trying to meet CAFE requirements and sell cars based on HP and gas mileage, a low restriction path to the TB is a cheap way to help get better figures.JBeezy53 said:Why did you switch to the 94/95 meter?
Maryland Stang said:As impressive as you think your easy find was none of those adapters will fit the MAF from a 94/95 Mustang.The inlet is way too big for the Mustangs air filter hose and the bolt holes don't even come close to being right. Been there, tried that.
The link doesn't work when you click on it. The page cannot be found.postalbunny said:Found this on ebay... for $5 plus retarded shipping, was still under $10 and worked great. Fit right on, had to get my own bolts (found laying around). Seemed to fit /w my ebay cold air intake better too... guess because it's longer than the factory maf.
http://cgi.ebay.com/ebaymotors/94-04...spagenameZWDVW
I searched for "MAF mustang adapter", get the "v6" one as it's 3.5" and fit /w my 94/95 maf adapter I got off ebay for ~ $30-$50
postalbunny said:Not sure why, but the 3.5" adapter is listed as "v6" mustang.
89lxcoupe said:i bought a explorer intake and throttle body and mine bolted directly on with no modifications to the throttle body and i had the breather tube ? maybe mine was a different year.....
89lxcoupe said:i have a 70 mm housing off a 95 gt if anybody is interested just put your sensor on it ! how much you give me.....
