My 95 was running just fine until the other day when I turned it off at Lowe's and when I get back in the car it wont start. I have replaced the CCRM, fuel pump, Cam positioning sensor, and crank sensor. The motor turns over and won't start. I am not getting power to the crank sensor, injectors or coil, I have had this checked by 3 people already. My question is what else am i missing here? Also the fuse box under the hood has no power to the "L SPD EDF MNTR" fuse, and if I am correct (if they are on the same line) the CCRM Fuse under the dash doesnt have power either. I have heard something about the anti-theft system on the car cutting power to these things and a few more things, or could it be the ECM or something else.
Thanks, Calvin
Thanks, Calvin
