front suspension...no, rear suspension...with some work.
You can convert the rear into a leaf spring rear without to much trouble and make it work. The front suspension is not worth messing with. The engine/trans/seats can all be used.
all depends on your abilities and patience. you could graft the 95 to the 65. i've seen it done with a fox body. i would imagine it would only be worth it if the sheet metal of the 65 was in need of replacement anyway.
