Anyone successfully installed the UPR brushed aluminum gauge cluster bezel?
I bought one with the matching A/C knobs last week. The knobs were a 1 minute
install and look pretty good, but would better if I could have got the bezel on.
OK ...I had the dash all taken apart and removed the black plastic unit with the
clear glass (actually plastic) attached to it. It appeared to be permanatly attached.
The glass has to come off to get the bezel in. So I called UPR and they said to
use a razor blade to break the seal which he said was silicone. NO go.... mine
is glued with epoxy or something. When I tried to force the razor blade in, the
glass started to crack so I reassembled as is before I broke the glass or bezel.
