a/c rebuild q's
sshakrr
hi everybody i need some help/advice on making my a/c work again on my 88 lx 5.0. its an auto, and the compressor still works, i think it just needs a recharge. what tools do i need to separate the lines, and does ford or anybody sell an o-ring kit? is it a hard project to tackle? im pretty mechanically inclined, just never did this before.any tips or things to look out for would be greatly appreciated. Thanks Ron
First you need to find out exactly why it is no longer working. If you have no freon, you need to fill it up and add dye to find any leaks. Then you will know what you are dealing with.
Turn the car on have someone turn on your AC while you have the hood open and looking at the compressor. See if the clutch engages, if it does, see how long it stays engaged. If it constantly cycles on and off, then you need refrigerant. If it doesn't cycle on at all then you need to look into WHY it is not coming on.
Start there and report back.
there is an easyer way........oil is carried with thr refrigerant....look for any leaks(oil residue) around all the connections and the compressor. You can check the compressor by jumping the switch on the drier(located on pass side firewall). Take a wire and with the a/c switch on in the car jump the switch.... the compressor should kick on....listem for a soft pulse....if its really loud like a knocking than the compressor is shot. I would replace all the spring lock seals and o-rings anyway and go from there........good luck.
Thanks for the replies. The clutch is kicking in and cycling. It does need a recharge. its a 1 owner 46k mile car. where can i find info on which o-rings are needed for this unit? Id like to replace them and then fill the system. I had them replaced in early 1994 before the ex. warranty ran out. it worked good until 2 years ago. id bet the o-rings just dried out. the system all seems to work just blowing hot air. Again any help is appreciated. Thanks again Ron
you find which o-rings you need by taking the old ones out. i dont think anyone has cataloged what sizes you need for what fittings. if you have a fitting with a nut, it is called a tube-o fitting, and takes one o-ring. if you have a spring-lock fitting, that you need the tool to separate, then you need two o-rings the same size for that one. and of course the bolt on manifolds on the compressor take two o-rings each. the pressure switch on the accumulator (tank on the firewall) uses one o-ring.
Check the service ports before you begin. Car equippedwith red & blue Service ports have been converted to R143a. Cars without the red & blue service ports are probably still R12, and need converting.
R134a Air Conditioner Conversion
R134a = $7-$10 a can – takes 2 - 2 ½ cans.
R134a compatible oil = $5-$7 for an 8 oz bottle – better get 2 bottles.
Gauge set for recharging = $20-$120 – check out the pawn shops for a bargain before you pay retail.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92649 is the A/C charging gauges that you will need.
Vacuum pump – I use an old refrigerator compressor = $5- $20 at used appliance stores, or go to the Dump and get one for free. Be sure to have some R12 compatible oil handy to keep it lubed up properly.
Pump to force cleaning fluid through the system $20-$50 (may use compressed air to do the same thing).
O ring seal kit = $8.
R134a charging adapter = $13 ( I cut mine up to use it with the R12 gauge set that I have had for a long time).
Plastic tools to disconnect refrigerant lines - 1/2" & 5/8" = $4 each.
Flushing agent - Discount Auto Parts has some flushing solvent in a 1 gallon plastic bottle - try that first. Or use Mineral spirits = $4 a gallon, tetrachloroethylene =$5-$10 a gallon, takes 2 gallons of either one.
Miscellaneous hoses and fittings to adapt the flushing pump to the system, and the R134a adapter to the R12 gauge set = $15.
I did a R134a conversion on my 89GT, and used all stock parts. You will need to replace the dryer/receiver (about $75 if you get the one with the hose made as part of the unit), and should replace all of the rubber "O" ring seals as well. You will need to drain all of the oil out of the compressor and replace it with new R134a compatible oil.
Keep in mind that to fulfill the requirements of the EPA, you are required by law to recover any refrigerant that still remains in the system. How (or wither or not) you accomplish this is up to you. Connect the charging gauge hoses to the service ports on the A/C (red gauge = high pressure, blue gauge = low pressure) and open the valves on the gauges to dump the remaining refrigerant (if any) into your "freon recovery system", whatever it may be. Disconnect the charging gauges since you are finished with them until you are ready to fill the system with R134a. Next comes the nasty part – in order to get all the old oil out of the system, you will need to flush it with special flushing solvent, or mineral spirits (ok) or tetrachloroethylene (better, but may be hard to get). If you leave the old oil in place it will congeal and reduce the heat transfer in the condenser and evaporator (read that it won’t cool good) and possibly damage the compressor.
Disconnect the compressor and remove it from its mount to flush it with cleaning solvent. Pour about a cup of solvent into the suction port and turn the compressor center hub about 10 turns while shaking the compressor to move the solvent around inside the compressor sump. Drain the flushing solvent out and continue to turn the center hub by hand to force out any remaining solvent. Then fill it with oil: add about 6-8 oz of the new oil to the compressor large suction fitting. Turn the compressor center hub about 20 turns as you turn the compressor face up and face down to distribute the new oil inside the compressor. Catch and replace any oil that comes out of the compressor.
Connect the pump (I had an electric sump pump I bought for $20) to the hose from the high-pressure side of the compressor. Alternately, you could use compressed air to force the cleaning fluid through the system. I didn’t like to do this since compressed air has lots of moisture in it, which is death to A/C systems. Pump the cleaning fluid through the system and let it come out the hose that was attached to the old dryer/receiver. I used 2 gallons of mineral spirits and pumped it all through the condenser and evaporator. The expansion valve is located near the firewall in the high-pressure line of the evaporator, and may cause the cleaning fluid to trickle through the lines at a very slow pace. You may want to pump cleaning fluid through the evaporator and condenser separately to speed up the process.
Next comes the changing of all the old "O" rings so that the chances for leaks is minimized. Use the plastic connector tools to separate the lines, place the extended collar part of the tool so that it faces the large part of the connector and push inwards: this expands the spring so that you can pull the tube apart. You may need a helper to push on the tool while you pull on the tubes to separate them. Install the new "O" rings: be sure to coat them with new oil when you put them in. Install the new dryer/receiver, R134a service port adapter, compressor, add about more 4oz of oil to high pressure line and tighten up all the lines. Close the hood, start the engine, let everything get warm under the hood, but don’t add the R134a or turn the A/C on. Connect the charging gauge hoses to the service ports on the A/C (red gauge = high pressure, blue gauge = low pressure) and open both valves, then connect the center hose to the vacuum pump. The purpose of this exercise is to heat up the system so that when you vacuum it all down (yes, you will need a vacuum pump- mine is an old refrigerator compressor), that all the air, vapor and moisture from the cleaning fluid vaporizes and is removed from the system. Vacuum it down for about 30 minutes, this should give you about 28" of vacuum or more inside the A/C system. I have a vacuum gauge "T" connected into the vacuum pump line so that I can accurately watch the vacuuming process. This is a good time to take a soda and sandwich break since it doesn’t go faster if you watch it.
Install the R134a service fittings on the system: the red goes on the high side and the blue on the low side. This will help others identify that a R134a conversion has been done on the system.
Remove the electrical connector from the dryer/receiver and jumper the two connections inside the wiring harness side of the connector together: this allows the compressor to engage in spite of low pressure/no gas in the system. Close both charging gauge valves, and then disconnect the center hose of the charging gauges from the vacuum pump and connect it to the R134a can tapper. Put the R134a can in the can tapper and screw it down with the can tapper valve closed, then open the valve. Loosen the hose at the center connection of the charging gauge set until the R134a squirts out: this purges the line of air and moisture. The refrigerant is added through the low pressure side of the system, so open the low pressure gauge valve to add the R134a. Start the car and take note of the idle speed, then set the idle speed up to about 1200-1500 rpm, and turn the A/C on inside and set the fan speed on high. Watch for the pressure on the low side to drop off as you are filling, and the R134a can will get warm and stay warm. This tells you the current can is empty and needs to be changed for a fresh one. Before you disconnect the can, be sure to close the valve on the R134a can tapper.
Watch the high side pressure on the charging gages and regulate the adding of gas to keep the high side pressure under 350 psi. You will probably need a fan in front of the car to keep the readings below 350 psi. I had to put the R134a can in hot water while I was charging the system with it, or else the can got so cold that it quit flowing. Use caution when you do this so that you don’t get water in the charging adapter when you change the cans. When you have added the 2 cans of gas, the high side will read about 250-300 psi and low side about 28-38 psi. Turn the idle speed back to where it was, turn the A/C off, disconnect the charging gauges, and re-install all the caps on the service ports. Remove the jumper from the low pressure switch harness and plug it back on the switch connectors. Then put the R134a Service Sticker on, secure all the loose wiring on the system and you are done. I hope it cools good, mine doesn’t get quite as cold as it used to driving around town.
The above technical note is for informational purposes only, and the end user is responsible for any damages or injury. The end user bears all responsibility for proper recovery/disposal of any R12 refrigerant.
I have an EPA 609 MVAC certification. And yes, you can shortcut the process, but there are negative factors if you do. Sooner or later, something will cease to function like it should. Shoddy work is a time bomb ticking away, waiting to explode.
A/C charging gauges:
Vacuum pump
My current vacuum pump is a refrigerator hermetic unit (motor & compressor in one unit). It was a freebe from a local used appliance store. I bolted it down to a piece of plywood & soldered a 1/4" flare fitting on the suction line. It works great, pulls 29" of vacuum in about 10 minutes or less. I have used it several times and have had excellent results.
attachment.php
Jrichker,
Thats a great writeup! Where do you find the "O" ring kit you mention for $8.00?
All I can find are individual "O" rings.
The $8 figure was several years ago, and it bought a kit with 2 each O rings in 3 different sizes. Advance Auto Parts was the supplier
