Ok, the time has come to finally get myself a set of heads. I'm looking for the best bang for the buck, and can't decide between TWs or AFR 165s. I was thinking 185s because of the possibility of making more power with them, but they're only going on a stock Explorer short block, so I really don't have the need for 185cc runners, nor do I want to make larger reliefs in the pistons. Enlighten me oh ye 5.0 Gods, you're helping me with my decision here.
My combination will be as follows:
AFR 165 or TW heads
Typhoon intake
70mm TB
75mm Pro-M MAF (have one calibrated for 19's that I'll have recalibrated)
24 or 30lb injectors
And I'm also still up in the air on which cam to get. The TW stage 1 would obviously be good for their heads, but what about the AFRs? I'd like to do a custom cam, but that's fairly cost prohibitive at the moment, since I have many other parts yet to purchase (new lifters, roller rockers, pushrods, gaskets, injectors, etc.) What does everyone think? Any pros/cons to either one that will help me decide? Thanks!
AFR 165 or TW heads
Typhoon intake
70mm TB
. It is commonly accepted fact, regardless of which head you prefer, that the TW heads are more likely to cause piston to valve clearance problems because the angle of the valves is different from stock (meaning that the reliefs cut into the stock pistons are not quite in the right place to provide the same level of clearance for a TW head as for a stock design head). How many other heads have pistons specifically cut to fit them? If you are building an engine, it won't really matter either way since you will be selecting new pistons -- but if you are upgrading the top end with a stock shortblock, it is a concern.
And you still post up a response like that? Your words of "they are all hype blah blah blah" is a statement of almost jealousy. The fact is THAT THEY WORK! Period. End of discussion. Are they the only option? Hell no. But you cant take anything away from them just because everyone runs them.
