Adding heads and cam, how much increase?
  • Thread starter Thread starter jhop1
  • Start date Start date May 1, 2004
J
jhop1
24
  • May 1, 2004
I have a 289 with about 275hp and 300tq, it has a mild cam with .496 lift, and 3.55 gears, 2000 stall converter. I was wondering how much of a hp and tq increase would a compcams, xe274h and a set of trickflow twisted wedge heads give me, also changing the rocker arms also. and right now my compression is 9.5:1, how much would the cam and heads raise my compression, also im going to swap the converter for a 2800+ stall. Please let me know what you guys think.
Max Power
1,774
St Paul
May 1, 2004
  • May 1, 2004
Dont think the cam change would add much. It's hard for someone to guess at a HP increase or compression change when you haven't told us anything about the heads your using.
allcarfan
The Answer Man
2,458
North Atlanta
May 1, 2004
  • May 1, 2004
You have 275 hp and 300ftlbs torque with nothing but a cam?? have you ever been on a dyno?
Are the pistons stock?
If so...you wont be able to use the TW heads.
the 274H cam is a fairly large cam....especially for your application, again, with stock pistons, i doubt you could use that cam.
if things were set up properly...I could see a 75hp + increas
J
jhop1
24
  • May 1, 2004
Yeah I have stock rods and pistons, put no, i have a edelbrock 600cfm carb, cam, weiand stealth intake, march pulleys, electric fan, headers, dual flowmasters with H-pipe. So if I did a 347 stroker kit, with the tw heads and that cam, it would have alot more power?
Max Power
1,774
St Paul
May 1, 2004
  • May 1, 2004
Yup!
allcarfan
The Answer Man
2,458
North Atlanta
May 1, 2004
  • May 1, 2004
you could crank out 500hp from a 347 with tw heads
Y
Dyno Comparison for TFS 44cc Ported Heads vs PI Ported Heads with same VT Stage 2 Cams
  • Yel2002GTAuto
  • Oct 13, 2022
  • SN95 4.6L Mustang Tech
9K
SN95 4.6L Mustang Tech Jan 29, 2023
Yel2002GTAuto
Y
LESS THAN 9.5 MPG CITY DRIVING!!!
  • PonyGTrider
  • Dec 15, 2022
  • 3 4 5
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 6, 2023
PonyGTrider
W
How much HP/Torque have I added with these parts?
  • Walker410
  • Aug 29, 2021
1965 - 1973 Classic Mustangs -General/Talk- Aug 30, 2021
Engine Cam idle and timing questions - big cam, little knowledge
  • Justin87
  • Jul 6, 2021
11K
Fox 5.0 Mustang Tech Jul 31, 2021
Middleagecrisis
M
SOLD 1993 Mustang LX Notchback- 347 Stroker
  • Bzammitt
  • Jun 19, 2021
6K
Fox Body Mustangs For Sale (1979-93) Jul 10, 2021
Bzammitt
