  • 1994 - 1995 Specific Tech
Adding some new mods...
  • Thread starter Thread starter ARed1995GT
  • Start date Start date Sep 13, 2004
ARed1995GT
401
Boca Raton, FL
Sep 13, 2004
  • Sep 13, 2004
Ok guys, I'm going to be adding some new mods pretty soon...
MAC Longtubes
Aeromotive AFPR
Pro-M 80MM MAF
24# Injectors
Switching Performer RPM upper to Performer 5.0 upper
I hope to see a decent increase in my sotp meter . 24# injectors won't really hurt my performance at all right? If the fuel pressure is around like 40, that should be good right? Hopefully... hopefully... next time I go to the track I will see 13's and higher traps than 97.5, also need to get my 60's down some...
Killercanary
The car that set the bar.
Altoona, PA
Sep 13, 2004
  • Sep 13, 2004
With those mods, I'd expect 100mph+ trap speeds. You may need lower than 40lbs of FP. Best bet is to set it at 36-38 and then make a pass and then addd a lb or two and see what happens, if it picks up you are on the right track, if not back it off a little.
Joes95GT
3,132
Delaware
Sep 14, 2004
  • Sep 14, 2004
Killer is right.
Full Length headers will cause the computer to dump more fuel because the oxygen sensors are located much further back, resulting in a "cold" reading. On my car, I'm running 38 PSI with 24 lb/hr injectors. I'd start with 36, but wouldn't go any lower than 34.
Joe
R
rudeone707
1,829
Fairfield, Ca
Sep 14, 2004
  • Sep 14, 2004
Joes95GT said:
Killer is right.
Joe
Do cereamic coated headers remedy the problem??
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Sep 14, 2004
  • Sep 14, 2004
ceramic coated headers would help out the problem because they'll hold more heat inside.
Joes95GT
3,132
Delaware
Sep 14, 2004
  • Sep 14, 2004
In theory, ceramic coated headers should help, however I don't think they are a solution to the problem. Here's why:
Our cars use what's called HEGO (Heated Exhaust Gas Oxygen) sensors, which means they have to be heated to work properly. They are heated from the exhaust and operate in obnoxiously hot temperatures; somewhere in the 600*+ range. Anything colder than that, and the car does not get a proper reading.
When they are moved downstream (further back) more heat is able to dissipate and cool before getting to the sensor. When they don't have hot enough exhaust gas temperatures to bring the sensor up to temperature, it causes the motor to dump more fuel. This results in an unnecessary rich condition, which most remedy by knocking back the fuel pressure a few PSI.
Joe
stunner6910
580
south texas
Sep 14, 2004
  • Sep 14, 2004
a little off topic, but everyone now seems to be after this damn bar where is it so i can start my adventure
Joes95GT
3,132
Delaware
Sep 14, 2004
  • Sep 14, 2004
It's a rear-end away from me. Once I bulletproof my rear (for good), the 60's should be down (hopefully) into the 1.7's and maybe into the 1.6's.
Joe
Killercanary
Altoona, PA
Sep 14, 2004
  • Sep 14, 2004
Its in my sig!
ARed1995GT
401
Boca Raton, FL
Sep 14, 2004
#10
  • Sep 14, 2004
  • #10
thanks
ARed1995GT
401
Boca Raton, FL
Sep 14, 2004
#11
  • Sep 14, 2004
  • #11
nittos are also in the future ;o
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
