jstreet0204
This is true, I don't use a flash tuner. I use the tweecer software, and a laptop, which allows basically full control over nearly everything in the eec. With it I can datalog boost, rpm, a/f, etc.Give Me TP said:You can. You need a wideband that datalogs A/F vs. rpm and a place where you can run at WOT in fourth (for 5 spds). However, as jstreet0204 posted the flash tuner unit itself will only allow you to add or take away fuel, only within fairly broad ranges of rpm and only at WOT.
