Yes it's still there, hose cut and capped. Other hose going to smog pump.If you want to see if it's the O2 sensors, swap the two sensors to other sides and see if the codes changes. If it does, buy a new sensor. Vacuum leaks can also cause the code, or a big exhaust leak as well.
As for vac line to the fuel tank, is your charcoal canister there?
Where is good spot to do smoke test from for vacuum leak?
