You had to have used the nitrous, Right! what numbers was that ranger making if you know? What are your 1/4 times without the TNT?onefast945.0 said:have'nt raced a s10 350 swapped,but i have raced a ranger with a built 351 on my blown coupe,lets just say,i blew by him.
Why is questionabe since we raced on the same track. At the time it was quicker than the Ranger, but that changed with added nitrous, already being used in the S10.
fivepointNO said:I watched my brothers 302HO(well built) Ranger run an S10 with a 400sbc in it. The result wasn't pretty for that S10.
Same guy had one with a 383 that ran upper 11's, but he claimed 9's.Why is questionabe since we raced on the same track. At the time it was quicker than the Ranger, but that changed with added nitrous, already being used in the S10.
That Ranger is quick and he raced several S10's, only losing to the one before adding nitrous. We knew of another that was much quicker than either, but it had real work done and by the time it was really quick, was no longer street legal or street driven. I never got to see the engine, but he claimed it was a 406.
I've raced a few S10's on the track, but never bothered on the street. Most I ran were in the mid 15's and powered by 305's. Some guys even thought they'd installed a 350... It's weird how you see that stufff and you instantly know who built their own engine by then. I remember one guy using a 350 in a Ranger. That was quick, running 12's commonly. And there are several 302 powered Rangers, many of which the owner thinks he got an HO(but didn't) and most are quite gutless. I knew one guy who used a Crown Vic engine thinking it was an HO. He couldn't figure out why his Supercab Ranger only ran 16.30's! He finally got a decent engine and managed 14's. Somehow, this satisfied him. As for me, I'm basically never satisfied!
Good luck with that stroker!
I wouldn't say that. First, it's hardly the only real difference. You don't simply have an HO engine by a cam swap from a standard 302. You don't gain 35hp from a cam swap alone in most cases, including that of the 302.dastang2 said:so you are saying that the lack of a roller cam costed that ranger 2 seconds. since that is the only real difference in an HO motor, i don't think something was up to par on that truck.
I need to update my sig.I sold the 94 5.0 like a year ago,now i have a highly modded 91 coupe(h/c/i stroked 351),and a blown stocker 93 coupe. I beat the guy like 4 cars ahead. My mods are: novi 2000 pushing 13 lbs.,stock 55,000 original mile 302(never unbolted heads,cam,intake),4.11 gears,stock aod/lentech 3200 stall,full exhausted(l.t headers,x-pipe,borla stinger mufflers), 70mm bbk t.b. 77 pro-flow meter,upgraded fuel system. Oh by the way,you would kill 5.0 on a ****ty 305? hmmm, interesting. Was the 305 highly modded? because i would murder tpi or efi 305 back when i had my 94 5.0 STOCK. and well a 350 lt1 or tpi,i had troubles when i was stock,but when i modded my 94(h/c/i juice 5.0) it was a different story including the modded chevy's!.S10V8 said:You had to have used the nitrous, Right! what numbers was that ranger making if you know? What are your 1/4 times without the TNT?
I remember racing, likely stock 5.0's when I had a ****ty 305 in my truck, and I would kill them from light to light with like 150hp at the crank, but traction to power was good with that combo. Now I have a 357with stock 882's, (soon to be 385with AFR 180 heads), somewhere in the 330-350hp range and go up in smoke because I only have cooper cobra 275/60's. I can only run 14.31 @98.8 when I don't even spin the tires, and hardly touching the gas for the first 150 ft to do so.
How do you like the dart heads? Are they the pro 1's or iron eagles? I am pretty sure I will go with the AFR 180's. This combo made 471hp at 5500, and 515 tq at 4500. 433 tq at only 2500 rpm. Will be a crazy truck if I can get it all done.Smokedawg said:I still have my S-10 and the Mustang.
The Mustang ran 11.97@115mph. That is all motor-no tune(just set fp at 40 and timing at 15), and no nitrous. I didnt get a chance to run the S-10 but I can tell that it will run circles around the Mustang. I say the truck should run high 10's, low 11's all motor. I have some big plans for the S-10 and Mustang this winter![]()
-Smoke
