Anybody running a cam with their Aode without a stall?
I run the Steeda 19. My car is also a AODE, which is stock.
Currently, the car isn't tuned. It will be once I get the Intake and Injectors.
Eventhough it runs fine w/o a tune, like it's supposed too, a tune could only add more hp.
I plan on adding some 3.73's, hopefully soon, then I guess I will need to look into a TC the way the posts here are sounding lol.
That is what I ws hoping someone would say about the Steeda 19. What ratio rr's do you have?
Sorry it sounds so confusing :scratch:
iphiniti im running an AODE also it will probably last forever for this horsepower level and the way its build. what i meant is the 4R70W would allow you to accelerate a little faster because of the higher gears in it .would it make a big difference :shrug: , maybe someone can chime in....
Ga94gt you can probably talk Ed in doing a cam for your setup where the powerband comes in much sooner, lets say 2400 rpm or just run the #19. try it for a while without the converter, and when you get tired of being left behind of the line get one :D
good luck
