Anyone running 275/55/r17's?
atrainsgt
39
I'm trying to decide on new tires and I was thinking about getting a thicker sidewall this time and a little bit wider. I have Toyo Proxes 245/45/r17 and they are way to narrow. What tires do you all like? Most people seem to be running 275/40/R17 but I wanted more sidewall this time but I might go with something different.
I have BFG G-Force Sport 255/45zr17 on all four corners. I like them, they look pretty good (with 25mm rear wheel spacers) on the stock bullitt-type wheels. I also had the balance weights mounted on the inside of the wheel and replaced the locking lug nuts with stock ones.
275/55 are kinda expensive, you'll have to recalibrate your speedometer, and they may not fit right on a stock wheel. I like the 255/45s, they are reasonably priced, but they probably are not what you're looking for. Good luck.
:flag:
ive got 285/40/17 good years on ford cobra wheels (not the R style), and lemme tell ya there whide as crap and lovem. i do have longer studs and 7/16 wheel spacers. i did check with spacers off and yes they did clear.
