Anyone who tunes, wants to tune or is interested should read this
Vic_Ferrari
273
lake mary, FL
This is a statement made by Jerry From SCT (Superchips Custom Tuning) in another forum.
It clears up a lot of misconceptions about tuning, commanded air/fuel ratio and the MAF.
I've been preaching that commanding a richer air fuel to attain the correct air fuel is WRONG, and this helps explain why (especially on an 03 Cobra)
Jerry is a highly respected mentor of my mentor Dave Caine
here it is:
All those interested in tuning - Time to bring the tech
I think it’s time to register for this site and clear a few things up.
First off you need to understand a mass air system. A mass air system measures the MASS of air flowing into the engine. There are several ways that this can be done, none of them are important for this discussion. Air-Fuel ratio is a ratio of the MASS of air the MASS of fuel. So if you are commanding a given air-fuel ratio and you know the mass of air coming into the engine, you know the mass of fuel that needs to be injected as well. If you know the total mass of fuel you want injected and the injector flow rate and the number of injectors, you then know how long to hold the injectors open for to get that desired amount of fuel. Notice how boost or location of the MAF and things like that didn’t come into that explanation? Because it’s necessary, that’s why. Putting on a supercharger just increases the mass of air flowing into the engine. More boost normally means more air mass and hence it will calculate more fuel needed.
(Here is a good place to mention that the reason for needing a "chip" on an ’03 Cobra, once you’ve changed the pulley, relates to some logic that, above a certain air flow relative to a lookup table, the MAF is ignored. By changing this one value, this problem goes away and it works just like described above.)
So, as long as your mass air meter does not saturate (meaning the output of the meter exceeds the 5 volts that the EEC will acknowledge), and the transfer function within the ECU is correct (meaning at that given voltage the air flow that it thinks it has at that voltage is correct) the ECU will automatically calculate the correct amount of fuel to inject and deliver that fuel. So, if you run more boost, the EEC will automatically put in more fuel at any given RPM based on the air mass increase. Now, if the air meter saturates, you have a huge problem. Then means the ECU no longer knows how much air is flowing into the engine so it no longer knows how much fuel to inject. In this situation, the engine then starts to drift lean; pretty much any KenneBell car with a stock MAF does this. Yes, many people will "rape" the calibration and do things like command a richer and richer air-fuel ratio to maintain a constant air-fuel ratio. This is a failure waiting to happen. If you set up the table to give you 12:1 air-fuel ratio with the MAF pegged, and now you get a day with better air, the engine WILL run leaner. Five percent better air is 5% leaner than when it was on the dyno. Same thing applies if you try to use the volumetric efficiency table when the MAF pegs. This specific table gets heavily modified based on a bunch of things, most of which no longer apply correctly due to the mods on the vehicle, and the motor will NOT be right as air density and air temp change.
Let me explain boost. Boost is nothing more than the measure of backpressure in a system, not the measure of flow. Rather than get into a textbook explanation of this, I’ll give an example.
You have a totally stock 4.6L motor. You add a Vortech Supercharger and power pipe and now it makes 10#’s of boost with a 3.48 pulley. Well, you didn’t upgrade the fuel system correctly and now hurt the motor. While it’s out you decide to perform a few upgrades. You add a set of ported heads, better camshafts, ported Bullitt manifold, headers, all the good parts. But you decide to leave the 3.48" pulley on the blower. When you get the motor back together and run it, now you only have 7.5#’s of boost instead of 10. Why? I’m sure most of you know why, it’s because by opening up the induction and exhaust system increased the flow through the engine so much that there is less restriction that the blower is pushing against, so it has less boost. But, it definitely makes more power, a lot more power. The blower doesn’t have to work as hard because there is less boost (since the power to spin any positive displacement pump is a function of the pressure drop from the inlet to the outlet), and at a constant compressor speed, the flow of the blower increases if you reduce the pressure drop across the blower. If you don’t believe me, check out a compressor map on Vortech’s site. So you have more airflow, more power, but less boost.
Now, let me talk briefly (Ha!) about an internal combustion engines spark requirements. Volumetric efficiency is the measure of actual air flowing into the engine, divided by the theoretical air flowing into the engine. So on a 4.6L if, in two engine revs, you flowed 2.3L’s of air, you’d have a voleff of 50% (2.3/4.6). If you had 6.9L’s of air flowing into the engine (this means air is being forced in by some power adder) then your voleff would be 150% (6.9/4.6). At a constant voleff, as engine RPM goes up, ignition timing needs to go up (more advanced). This is, in part, to compensate for the faster spinning engine needing to start the combustion process sooner so that it’s at the "right" point when the piston starts traveling down. At a constant engine RPM, as voleff goes up, the spark requirements of an engine go down. This is because the higher cylinder pressure, from more air being stuffed into the cylinder, (due to higher voleff) will result in a faster combustion process, so you need less timing for complete combustion. The above example does NOT take into account spark limits for octane or air temp, it is basically the spark needed to make peak power.
Ok, here is why a MAP sensor is actually bad to use for spark requirements. Remember the above example of the Vortech’d 4.6L? Well, boost went down when the motor was modded but airflow went up and it made more power. If airflow went up, then voleff had to go up. With a system that changes timing based on MAP, the above car would end up with more timing since there was less boost. Anyone that knows that knows anything about engines and tuning knows this would be bad. You just added a bunch of power, increased air flow, increased cylinder pressure, and your system just added more timing when it should have taken timing away. The PMS supporters will say that you just go in and change timing. Well, if the system is so good, then why do you have to adjust it for things like that? You don’t on a correctly setup mass air system.
Now, with a mass air system, it calculates volumetric efficiency. If you know the air flow going into the motor, the engine RPM and the engine displacement, you can calculate voleff very, very accurately. The Y-axis on the spark tables in the Ford software is voleff. In the above example you would see a higher voleff. If you set up the spark table correctly, you will now go in there and look up a spark value with a higher voleff, which is set up for less spark at this higher voleff. No need for boost reference, it’s based on how much air is flowing into the motor at that RPM.
Now a positive of the PMS is this; In the 1993 and older Mustangs, their spark at WOT is just a function of RPM, no input for voleff or airflow. Yes, if you run boost you can change this function to retard timing as RPM goes up but there is no compensation for anything other than RPM. The PMS will adjust spark, not ideally, for boost. In this dinosaur example, a boost sensor is better than nothing if spark if just a function RPM and nothing else.
I personally don’t care what the shop manual says, they are wrong. The Cobra does NOT use it’s MAP sensor for anything fuel related other than compensating for quick, transient changes in manifold pressure. Beyond this it’s only used for EGR stuff and barometric pressure calculation (no the BP is not used in the fuel calculation).
I doubt I cleared everything up, but I should have at least given you something to think about….
Very interesting read Vic. I have some questions though about the following statement:
Maybe he over-simplified this for some of the readers.... but how can changing just ONE value in/on a chip compensate for a pullied Cobra?
U.M.
It isn't always quite that simple, but the theory is.
The particular problem he is talking about goes away with a change of one value....that is correct.
The MAF table only reads to a certain voltage (or number of "counts") in the stock calibration. This max number of counts is often exceeded (more air coming in means more counts/more voltage) when a pulley upgrade in installed.
These are not correct numbers, nor will I disclose the correct numbers, but here is an example:
Stock pulley at WOT under boost (boost pressure is irrelevant, but the increased mass of air is) at 6,000 RPM, lets just say it MAF voltage 3.8 volts or 680 counts (not accurate, but it will work for comparison)
Now, lets assume the factory MAF calibration only "reads" as high as 4 volts or 700 "counts" at maximum.
You install a pulley, now the MAF is pegged because it can not reference high enough volts or counts to compensate for the airflow.
Maybe now it's at 4.9 volts or 1000 counts....doesn't matter because the factory calibration does NOT read here... it can't go higher than 4 volts or 700 counts
It ignores the mass air table and goes to a lookup table. (somewhere you don't want it to be).
As he was saying, if you tune it with the mass air pegged it may run GREAT that day......then a months later when the ambient temp drops and the air is denser, it isn't reading the MAF table and it doesn't compensate. BAD!
That's one reason how cars that read 12.0 across the line on the dyno end up 13.0 a month later! bad tuning....
As a result of a pegged MAF, you default to a table which attempts to compensate, and is not successful in doing so for any length of time or change in conditions. This is part of the reason why some tuners have AFR #'s all over the place because they don't know how to fix this properly. They attempt to do what jerry calls "whoring" the factory calibration by stabbing it with an obscenely rich "target" AFR, which may hit your target....for a while.
There are several tables that affect fuel directly and indirectly and these may or may not need to be changed in different situations, but the MAF must read high enough voltage/counts to meter the airflow coming in.
If you raise the max volts read to lets say 6 and counts to 1500 (again, two incorrect numbers) the MAF is able to read the increased mass of air "normally" without defaulting to a table it uses when the mass air is pegged.
"Pegging" a mass air is a term that often confuses people.
It is not that the MASS air is too small, it's that it electronically can't read any higher.
The factory calibration is set low, and you can raise it.
At a certain point, it can't be raised anymore and if you run out of "counts" again, you will then need a mass air upgrade. Will this comes the responsibility of making sure it's calibrated correctly through the program.
I am at the verge of my stock mass air running out of counts, even with counts raised.
If I added another pulley, a kenne bell, etc.....I would need a mass air upgrade.
Some aftermarket MAF manufacturers (particularly the "G" word) say they have calibrated their MAF a certain way and it never seems to be right.
Other places, like C&L seem to be pretty close.
Interesting reading Vic. Most of it above my head, but I think I grasped the point. If I were to, say put a Kenne Bell on a stock 98 Cobra, if the MAF had a large enough voltage/count, then the cpu would keep the A/F ratio to what it needs to be, given the injectors are big enough to keep up with the demand? How do you tell the voltage and count on a meter?
Karl
Karl
The A/F would be where it needs to be provided the calibrator who tuned the car did his job.
If Ihad a KB or whipple, I wouldn't even consider the stock mass air.
A scan tool will tell you MAF voltage and some data acquisition programs will show mass air counts.
An NGS scan tool will work fine for MAF voltage.
You don't need voltage and counts......just one or the other....it's just convenient to have both.
They can be converted to each other.
I was fortuante enough to watch Jerry tune a few month back. The guy is simply amazing. He makes it look so easy.
In 3 runs, he tuned a 03 Cobra with a KB, cams and ported heads. The car came to him with a diablo chip tuned by strictly performance with 16 hours of billed dyno tunning done to it. Jerry baselined it with strictly's tune, then tuned it in 3 pulls to put down more peak power and torque, got rid of the surging that striclies tune caused, and the throttle response was amazing. Then He tuned a stock cobra R and got 20rwhp, 20rwtq out of it with a safer A/f and flatter curve. My jaw dropped watching the guy work. There is already a long list of people waiting for him to come back to get tunes.
Vic, I hope you don't mind if I copy/paste this at a different forum where the owner of the 03/R posts.
