Bad Master Cylinder?
gnx547
283
Lately I notice my brake pedal is soft and not firm. I recently replaced my wheel cylinders and I bled the right rear and the left rear. After bleeding it 5 times on both sides the brake pedal isn't to firm at all. When I test drove it and when stopping the pedal goes to the floor, its just not firm at all...So then I decided to bleed all 4 wheels again starting with the wheel far away from the master cylinder, which is the right rear..So after bleeding all 4 wheels, its still not firm at all..I check for leaks around the master cylinder, front & rear brake lines and hoses and no leaks at all. My front pads are good and my rear shoes are good with new wheel cylinders..Could I have a bad master cylinder causing a soft brake pedal and not firming up after bleeding?
With the car off, pump the pedal. After 3-4 pumps, does the pedal get rock hard??
If you hold it pressed...does it eventually bleed down??
How about when driving. If you do rapid pumps when stopping, does the pedal firm up??
Yes with the car off 3 to 4 pumps the pedal does get rock hard...It does hold but when I start the car and start driving the pedal does sink down and its not firm at all...I bled all 4 wheels several times with no improvement and I have no leaks at all..I am thinking the master cylinder is bad causing my pedal to feel soft all the time and not being firm.
I was just thinking about this, when I put the shoes back on I put the drums on and I bled the wheel cylinders. After bleeding it there was a slight drag when I turn the drum. But I DIDN"T adjust the star wheel..Was I supposed to adjust the star wheel after I installed the shoes? After bleeding it I couldn't get the drum off, which told me the shoes expanded and adjusted automatically and I felt the slight drag when I spinned it, So I was thinking that the shoes are already adjusted because of this...Could it be that for me not adjusting the star wheel cause my brake pedal to drop down slightly & feel soft and not firm at all after bleeding the wheel cylinders? Should I go back and adjust the star wheel? Any thoughts?
