If it has a/c and p/s, it will likely take something in the 84" range; but all of these are a bit different. I bought 3 belts - 84.5, 84, and 83.5 and put on the one that fit the best; returned the other two. Parts place had no problems with that approach.
Look closely at the front of the tensioner and you'll see a small arrow with a "range" bar -- the correct length belt will put the arrow in the middle of the range. Put it on the loose end and a slipping belt can be the result; put it on the tight end, and you'll see lots of fine black powder all over the pulley areas -- and likely will break a belt shortly thereafter due to wear.
Good luckk with it!
