best 351c build up for street
lewis_dd
i have a '73 Mach 1 with the 351c 4v open chamber heads. I want to get some more power and speed from it my signiture shows what i have now. I have full length headers not installed tet, and could either put flat top pistons or put closed chamber heads a cam, etc.
any suggestions?
Thanks
Darren
i have a solid roller, 4v heads, long tube headers with 3" exaust, edelbrock dual plane intake, and edelbrock 600cfm carb.
I bought it like this, it doesn't pull hard until 4500rpm, and I think that it would rock with a different intake/carb
first decide what rpm range you are going to run this engine about 85% of the time. a street/strip motor is different than a race motor, is different than a daily driver motor.
Swap the factory cam for something better like a Comp Cams 268H. That would boost the dynamic compression to help the open chambered heads and should improve the bottom end. I'm not a fan of Edelbrock carbs, so I'd go with a bigger Holley like a 670 Street Avenger or list - 80783-- 650 cfm vac. secondary carb. Summit's cam part # SUM-K5200 would also work well. I used one in a stock 400M and it really woke it up. Same open chambered heads but with 2 bbl ports as your 351C.
For the street, get some Aussie heads (Closed Chamber, Small Ports) and a nice dual plane intake, a good cam, and good well tuned carb.
The closed chambers have much less trouble with detonation, and the smaller ports will have good TQ.
