Best Combination
  • Thread starter Thread starter Username69
  • Start date Start date May 1, 2013
Username69
10
Hawaii
May 1, 2013
  • May 1, 2013
So, my spelling is awful, and this thread probably exists in the past, but Venture Brothers is on.
My question is this: I have the H.O. 302. I am considering buying GT40 Turbo Swirl heads from American Muscle (Or Jegs, I think they are cheaper there). What would be the best intake to match those heads? Would the B303 Ford Racing camshaft I currently have in the engine work well with the heads? Would I have to upgrade my injectors, which are currently 24lb injectors? Would I have to upgrade the throttle body as well, which is a 65mm TB?
Several notes: I can't call the companies, such as Ford Racing and Jegs and American Muscle and Summit, because I'm on HST (East Coast is six hours ahead) and work early to late and most weekends. I don't understand injectors other than the principles, so I have no idea what 24lb injectors really are (first time playing around with a non carb engine).
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
May 1, 2013
  • May 1, 2013
:search:
Reactions: madspeed
Exile
128
Dallas, Tx
May 1, 2013
  • May 1, 2013
A B303 cam, 24lb injectors, and a 65mm throttle body will be just fine for GT40 heads.
What intake are you using? What size MAF (mass air flow sensor) are you using?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
May 1, 2013
  • May 1, 2013
ASK BERNIE!!!!!!!!!!! B CAMS FOR EVERYONE
HuskerNation
252
West Des Moines, IA/Omaha, NE
May 1, 2013
  • May 1, 2013
IMO, spend the little extra and go Edelbrock.
Username69
10
Hawaii
May 1, 2013
  • May 1, 2013
84Ttop said:
:search:
Venture Bros takes attention precedence. =D
Reactions: 84Ttop
Username69
10
Hawaii
May 1, 2013
  • May 1, 2013
The intake is the stock 1991 H.O. intake, and the mass air flow sensor I would imagine is stock, as I haven't messed with it.
R
reldla1996
356
22
Dayton, Ohio
May 2, 2013
  • May 2, 2013
I would go trick flow or edelbrock matching heads and intake for that. 24# injectors and 65mm TB are fine for that. You should get a 70/73/75mm MAF to line up with the rest of your combo, along with a 110/155 lph fuel pump. There are better cams than the B303, which is pretty dated, but you have it in hand, so I don't know that the difference is worth the cost. It will be a nice running set up if you do all this.
Username69
10
Hawaii
May 2, 2013
  • May 2, 2013
I'll look into the parts. Might as well check the fuel pump and MAF, because I don't know how big they are.
I was looking at the B303 and comparing it to the E303 and F303 (I think that was them), and I got the general impression the B303 was best if you wanted a street car that didn't need to idle at 1500+
Exile
128
Dallas, Tx
May 3, 2013
#10
  • May 3, 2013
  • #10
Well I would consider upgrading your intake to a GT40 intake (or better) to match your combo, as well as a 70mm+ MAF sensor to match the 24lb injectors.
R
reldla1996
356
22
Dayton, Ohio
May 3, 2013
#11
  • May 3, 2013
  • #11
The E cam is street legal, and will idle the best of the three. The F is a little more radical, with the B cam in the middle ground. All three are dated designs, and newer cams will perform better, but again, since you have the B in hand, I'd probably throw it in there unless you want significantly milder or wilder. The newer cams ramp up quicker and will have split duration favoring the exhaust a little. This can give you a little more power (and/or smoothness) over the older designs, nothing radical, but a little bit.
clement
1,104
52
59
Oak Cliff
May 3, 2013
#12
  • May 3, 2013
  • #12
if you are gonna run the stock intake there is NO, I repeat, NO reason to put heads on it. if you are gonna run most of the intakes on the market it really wont matter what heads you run because the intake will be the restriction. unless you run a TFS R or holley systemax 2. if I were going to run a package on a stock 302, I would do a TFS R, and a set of 170cc TFS TWs. I would run those heads because when you build a 408 later, you sent the TW heads to TEA or whoever and have them run a 205 cnc program through them. with the above heads and cam combo, I would do an Anderson n41 if u wanted to run off the shelf. if it were mine id run bullet lobes:
intake: HR271/332 on a 112* ICL and exhaust: HR275/330 on a 115 centerline.
fords2live
84
May 4, 2013
#13
  • May 4, 2013
  • #13
I had an E cam and it idle'd good at 800rpm.. No surge or anything else like that. Just sat at 800 all day.. Unless it was super cold outside then it wanted to die until it got a little warm. Had a good loping idle.
D
Tune erased/wont start/91 fox body
  • drew123
  • Jun 15, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 7, 2026
drew123
D
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
