Best Method
  • Thread starter Thread starter Shakerhood
  • Start date Start date May 25, 2005
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 25, 2005
  • May 25, 2005
What is the best method everyone has come across for removing and installing the Front Coil Springs on a Fox Car?
J
jerry beach
2,671
Ocala,FL
May 25, 2005
  • May 25, 2005
Dont put them back in, they are easy to get out. Install coilovers instead, simple but costly. I would not change the stock springs without going to coilovers. Ride becomes too harsh IMO.
HISSIN50
34
129
May 25, 2005
  • May 25, 2005
i do it with compressors but many like to jack the control arm instead.
Jerry - I would be if I did not know that you are being completely serious. to you and your suspension.
Stang8URMPRT
1,100
Daytona Beach, FL
May 25, 2005
  • May 25, 2005
I had to unbolt the a arm from the k member when installing my Eibach drag springs. There was no way possible that they were going in even with a spring compressor the conventional way (unbolting strut, letting it hang down)... things were huge, and a PITA to install.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 25, 2005
  • May 25, 2005
What kind of compressor do you use?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 25, 2005
  • May 25, 2005
I bought Bullitts, I think the ride and handling will be fine with them.
HISSIN50
34
129
May 25, 2005
  • May 25, 2005
i used an internal compressor (I dont have access to a clam compressor like Nick probably used at work). I did have to mod it a bit. I used a piece of pipe as a shim between the head of the compressor bolt and the compressor (or else the compressor bolt shank would bottom out in the frame before compression occurred) and I had to unbolt the butterflies (the hooks on the compressor) and manually insert them into the coils - then slide the compressor rod through. It was a pain on the first side but the second side went quicker. this was with stock vert springs.
But you want the best and quickest way, which is why i mentioned the jack under the control arm method above. that is likely gonna be quicker and easier (i have done this method, but not on a stang).
lowering springs would be a lot easier IMHO to install than stockers.
good luck with it.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 25, 2005
  • May 25, 2005
good luck with it.
I am pretty sure the Bullitts are a little bit lower than the stock springs, so hopefully that will make it a bit easier on the install portion of it.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 25, 2005
  • May 25, 2005
good luck with it.
Do you know what brand you have as the one I bought do not allow me to unbolt the butterfly hooks, they are 1 piece?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 25, 2005
#10
  • May 25, 2005
  • #10
In the Ford Service manual they show you having to undo the A Arm after you compress the spring, so its a given that they will have to come down after you relieve the pressure.
HISSIN50
34
129
May 25, 2005
#11
  • May 25, 2005
  • #11
Sorry - No idea on the spring compressor brand. It was a loaner from Autozone. I have been meaning to make a clam compressor - i think it would be useful.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
May 25, 2005
#12
  • May 25, 2005
  • #12
I might just use the jack to remove them. and then use my Compressor to compress my new springs and band them with something, remove the compressor and then install them that way.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
