Bleeding Brakes
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Okay, I bled all four wheel's brakes, but I was wondering...isn't there a central location that also has to be bled? The ABS center? If there is, where is it located?
if you just bleed the brakes and system was never totally evacuated. only place needed to bleed is at bleeder valve on caliper. unless you replaced master cylinder in that case master cylinder requires bleeding before its installed.
