Blower guys come on in!!!
  • Thread starter Thread starter GoBabyVroommm
  • Start date Start date Mar 27, 2008
GoBabyVroommm
1,156
Chicago, For Realss???!!!
Mar 27, 2008
  • Mar 27, 2008
Alright its a 93 LX. Me and my buddies got the blower on<s-trim 14lbs> So far the car has a 355 gear, Felpro head gaskets, and full exhaust. I've read that cooling might be a problem with this much boost is that true and how to fix it? I will be running a sn95 electric fan. I haven't got the inj. yet i'm still on there 19lbs still.<not even reving the car with them on> I'm looking at some 38lbs Inj to pick up soon. I have a FMU and 6AL msd box. With this set up should i run timing at 10 degrees and gap the plugs at .35? I'm nevered messed around with a 6AL due to the facti had a 4.6 in the past. How should i set up the 6AL? I just have a 255 in take pump i am planning on getting a pusher if need.
Any advice, hints? This is my first blower car, I've had nitrious in the past so i'm trying something a little bite different.
I did a search on blowers and read up but making a thread is pretty helpful. Guess it just comes down to simply just interacting with people is why a thread is more helpful.
N
NC5.0
25
NC
Mar 27, 2008
  • Mar 27, 2008
I have the pretty much the same set up as you. H/C/I + S-trim making 504 to the tires. I am running a electric fan off a SN95 gt as well with the stock radiator. It has cooled fine this winter but now that spring is starting to roll around with 75* temps and higher its starting to climb higher then I want. Right now its getting around 210* in traffic at 80 degrees outside. (I'm running a 180* thermostat with a electric fan controller to turn it on a 195* off 180*.)
I have considered a new radiator that is a Fluidyne copy made by Mishimoto for half the price of the Fluidyne.. A lot of sn95 guys are using Mishimoto radiators with great results. I haven't ordered it yet. I bet with our setups we will have some clearance problems with aftermarket radiator+ electric fan and s-trim. I only have about a 1/2" clearance at the most from it hitting the water pump pulley. I'm sure we can modify it to work though...
Here is the thread I started on the Mishimoto radiators. I haven't gotten much feedback off the fox bod guys but tons of people are running them on the sn95 cars.
http://forums.stangnet.com/showthread.php?t=743512
Maybe that helps ya..
N
NC5.0
25
NC
Mar 27, 2008
  • Mar 27, 2008
Oh yeah, and that was with about 12-13# of boost that I am running..
GoBabyVroommm
1,156
Mar 27, 2008
  • Mar 27, 2008
I have a 160 ther in my car now. Basicly what i'm trying to find out in this thread is this set up reliable? Since i was 18, now i'm 25, I wanted a 5.0 because of how much talk i heard about them. I heard there very easy motor to work on, cheap go fast parts, reliable, and not to bad of a power plant. Only thing i found not true is that a LS1 is a lot easier work on and i'm beginning to think the 4v cobra is easier as well.
Kind of off topic but...
If this set up is going to be popping rods, cracking blocks and melting pistons with 450 rwhp tuned i'm selling this mustang and never looking back. I'm hoping you guys can teach me, give me some ideas, and possibly goals you have with your stock motor. If this car/motor makes it past the summer without having to work on it everyday then i'll go buy a forged 306 r block and rev the piss out of it. =)
GoBabyVroommm
1,156
Mar 27, 2008
  • Mar 27, 2008
BTW NC5.0 nice car love the engine pics!
mustangfan1990
505
Lenoir, North Carolina
Mar 27, 2008
  • Mar 27, 2008
wouldnt say spilt the block at those numbers but it will be close
GoBabyVroommm
1,156
Mar 27, 2008
  • Mar 27, 2008
I have a question for u mustangfan. I think a S-trim is good to flow 660hp. I was wondering why not just boost your car higher to get those numbers than putting on heads/intake/cam? I understand the whole breathing thing and combo, but i'm just wondering?A 302 split under pressure at 530rwhp?
mustangfan1990
505
Mar 27, 2008
  • Mar 27, 2008
Yeah at 530 rwhp a block will spilt and the reason I am not turing my car higher is because my fuel pump isnt strong enough and leans out at 4500 rpms so I have to get a bigger fuel pump to keep it around 11.5 AFR. When I get a bigger fuel pump it will put around 500 rwhp
GoBabyVroommm
1,156
Mar 27, 2008
  • Mar 27, 2008
OO i got yea, yea fuel is a big problem with boosted cars. You can run 28/30s with 450 hp N/A cars with it was like that for boost.
HGFireHazard
460
Michigan
Mar 27, 2008
#10
  • Mar 27, 2008
  • #10
You can split the block at 450rwhp...
The s-trim puts a lot of pressure on the crank/bearings if you don't have a girdle and people have spun bearings after some time running a charger as well.
.035 is a good gap for a blown car, and the MSD box will help make sure you don't have any spark blow out.
The blower on the stock longblock (with a few bolt ons) will net you around 300-340 rwhp, depending on timing and the bolt ons. You shouldn't be splitting the block with those kind of numbers.
Get those bigger injectors in there and get her tuned up and she'll be pretty fast and pretty reliable.
mustangfan1990
505
Mar 27, 2008
#11
  • Mar 27, 2008
  • #11
Well mine will be putting close if not over 500 rwhp on my stock bottom end. I know it is a matter of time but we will see how long it last. It already made almost 460 at just 4500
GoBabyVroommm
1,156
Mar 28, 2008
#12
  • Mar 28, 2008
  • #12
So what should i rev this bad boy too? Its a lot different from my cobra that is for sure.
mustangfan1990
505
Mar 28, 2008
#13
  • Mar 28, 2008
  • #13
Well with 24s and a FMU you will get plenty of pressure BUT without a tuneI wouldnt turn the car hard at first. Keep an eye out on detnantion. Check your plugs after a few hard runs to see how rich you are running. You want to be a little on the rich side to keep from leaning out. Your pump is big enough. I would start out at low rpms and slowly get a little harder on it. If I was you though I would get 42s (or 60s) #injectors and a tune. Worth every penny. The car runs ALOT smoother with a tune too
N
NC5.0
25
NC
Mar 28, 2008
#14
  • Mar 28, 2008
  • #14
I wouldn't rev it over 6k making 490+ at the tires unless you want to take the chance of picking parts off the ground. Your stock block may not last that long if you do that. I was running mine on the dyno to 5800 rpm, (thats where my shift light was set). My block is probably on borrowed time as well though...
GoBabyVroommm
1,156
Mar 28, 2008
#15
  • Mar 28, 2008
  • #15
Well i don't plan on flooring the car till it gets a tune. Looks like i'll just wait to pick up some 42/60s and see how it goes. I would hate to half ass it just to floor it once around the block and then have to start taking it apart all over. Yes all over again because i just put it back after putting on Felpro head gaskets.
T
Resolved No run or idle
  • Thebluefox1
  • Oct 10, 2025
Fox 5.0 Mustang Tech Nov 25, 2025
DadLife0724
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
