T TRIBUNAL Active Member Jun 12, 2005 103 6 28 Mar 25, 2008 #1 Mar 25, 2008 #1 As the title says I got a 91 engine, 5.0. Polution **** is all removed. I need to know what type of bolt i need to plug the holes in the rear of the heads with. It looks to be close to 5/8 or metric... not sure. thanks, Ray
bloopbloob Member Sep 27, 2006 578 4 16 Alberta Mar 25, 2008 #2 Mar 25, 2008 #2 5/8", 11 threads per inch. or you can use a spark plug. or cut the blocks off the tubing, flip them and rebolt them on. all should work.
