Boostmaster bypass
Reef Blue 5.0
104
21
29
Orlando
019.webp Hiya bros, just installed my 3.33 pulley pack upgrade and aluminum H.O. discharge tube to my previously low boost entry level Vortech kit on my 93 5.0. I have the UPR boostmaster pipe (which has an awkwardly placed nipple for bypass pressure) and through reading other forums I've learned people are using either Home Depot 90 degree angled plumbing fittings with straight heater hose or L shaped radiator or heater hoses attached directly to the pipe to plumb the bypass valve. Does anyone have pics of either or both of these ??? Also opinions on which install is the way to go are appreciated. Thanks and happy boosting.
True you can do any way you really want. I prefer to tap the pipe and use use pipe nipples, 1 90degree and connect with 1" rubber or silicone hose
Sent from my XT907 using Tapatalk 2
