MBDiagMan said:Okay, vacuum bleeders have been around for decades, how long have ABS brakes been around?
Almost 50 years, but Bosch started development in the 1930s.
The automotive industry saw more widespread use in the late 70s, but apparently KH/TRW had a rear ABS system available for the 1970 Lincoln Town Car. I recall quite a few vehicles with early ABS systems in the late 70s and early 80s.
Your assumption doesn't make any sense because the ABS mechanical system does not activate until the wheel speed sensors tell the ABS module that the valves should start actuating. Until it does this, the ABS pump works like a traditional proportioning valve (remember those things?) Unless you have the special Ford diagnostic tool to cycle the ABS pump, a pressure bleeder would simply be pushing fluid/air through the inactive ABS pump (just like sucking fluid/air through the inactive ABS pump). You're assuming the pressure bleeder will push the fluid/air through the closed valves as well, which is incorrect based on how the TRW engineers explained the functions of the ABS pump.
:SNSign:
