I just put new calipers and rotors and pads on my rear wheels. They are stock replacements, just the normal stuff. When we took the old ones off, I did not plug up the brake line to prevent air from getting in. (I'll remember to read first before dismantling from now on) Now I can't get my brakes to bleed. To make matters worse, when I disconnected the e-brake cables from the calipers, I think something went wrong. I released one side with the e-brake on and then realized I should probably put it down. So I did, and took the other side off. When I hooked up my e-brake cables (I literally held that spring contraption with a prybar as far as it would go while my brother pulled the cable into its slot) I went to test it by pulling it up inside the car and it won't budge. It is stuck down. Now my brakes won't bleed, my e-brake won't budge, and my car is stuck on jack-stands until I figure this out. Please someone point me in the right direction. I am novice at this stuff and trying to save as much money as I can.(not very good for a sports car owner) Any tips on how to do this at home would be the best. I really didn't think this would be too hard, but its proving to be harder than swaping my clutch. Thanks in advance! Tswen.
