brakes
twolo4u2c2
5 Year Member
Apr 10, 2003
330
reading, PA
I currently installing 01 cobra front brakes and 94 cobra rear disks on my93 vert......I want to run 9" wide wheels. Does anyone have this combo running 9" or should I settle for 8". I know all about the wider stance with the newer stuff and I would rather keep all the wheels the same size. any help would be great.
thanks
I'm running '03 Cobra rims with Fox length axles, 9" rim with 7.11 " of back spacing if i remember correctly. With 275/40 tires there is some rubbing under moderate cornering, either on the quad shock or the wheel well. But it does clear the fender lip nicely.
is 7.11 backspacing factory or special order?:bang:
You know you can flip your Quad shocks to gain a little bit more clearance.
