c6 will it bolt up??
Dugan
47
Portage Mi
i found a c6 transmission for sale for a pretty good deal, i want to buy it but i am unsure weather or not it will bolt up without modification to my 302, i am pretty new to this stuff:shrug:
i don't know if it matters but i have a c4 right now..
yeah i am still unsure as to what is wrong with my c4, i have reverse but have lost all forward gears.. i then ran across this c6 and just thought it would be easier /cheaper to just swap it...
so what you are saying is the c4 is better than a c6?
Not better over all. Niether trans is better over all. Its the application they are used for. A C4 is better for a small block unless you are making stupid amounts of power. Even then a C4 can usually be built to handle damn neer anything. Your C4 is toasted and need a rebuild (at least I'd bet). Does it have enough fluid in it ? Other then that it sounds like you need a rebuild.
It sounds like the forward clutches are toast. I would stick to a C4 too. There is nothing wrong with a C4. A shift kit will help them live. If you don't want hard shifts, transgo makes one that is designed to extend the life w/o harsh shifts. If you go to a C6 the driveshaft will possibly need shortened. The output shaft may be different splines and u-joint size. May use a different cross member, starter, speedo gear, dipstick, shift linkage, kick down etc. Do your homework. Get the answer to all these questions before starting. It may be a can of worms.
