  • SN95 4.6L Mustang Tech
Cam and tune ?
  • Thread starter Thread starter jivepepper
  • Start date Start date Dec 19, 2006
jivepepper
776
Under a Sombrero. in WV.
Dec 19, 2006
  • Dec 19, 2006
I plan on installing some HP S292 SC Cams and dual focus pumps in my cobra fp set up. My tuner is 212 miles away do you think it would be safe to drive there?
R
RoadconeTuning
458
Upstate, SC
Dec 19, 2006
  • Dec 19, 2006
umm.... no... trailer that ish!
joshheat25
871
Delaware
Dec 19, 2006
  • Dec 19, 2006
yea def not safe!
P
Pennywise2
Banned
May 16, 2006
1,379
  • Dec 19, 2006
Don't do it.
You could tow it there and drive back after it is tuned
problem solved.
jstreet0204
939
Winston Salem, NC
Dec 19, 2006
  • Dec 19, 2006
Just drive normal and you should not have a problem. Keep it out of boost until you get the a/f checked out.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Dec 19, 2006
  • Dec 19, 2006
What are the cam specs on that? Is it 292 advertised duration??
Rickey_Bobby
332
Sarasota, FL
Dec 19, 2006
  • Dec 19, 2006
You can rent those little toe dollies from uhaul for $75 I think. In my book, thats $75 well spent. 212 miles is a LONG way.
My rule for stuff like this is, "Only drive as far as you are prepared to walk"
So that would be about 42 hours of walking...
jivepepper
776
Dec 20, 2006
  • Dec 20, 2006
Yes .531/.531, 292°/292° 114° lobe sep.
jstreet0204
939
Winston Salem, NC
Dec 20, 2006
  • Dec 20, 2006
For those that are saying it isn't safe, I would challenge them to explain why.
Here is my reasoning for why you will be ok. Assuming the cam install was correct and everything mechanically is fine, the cam does nothing to change the MAF reading. The MAF still knows just as well as before the cam swap, how much air is going into the engine. Now insome cases, it can require some tuning to adjust the injector timing to keep the from spraying on the back of the intake valve, but this is not something that would likely effect the a/f ratio during closed loop since the EEC will adjust to it. This is easy enough to find out, just drive it around for a while before going on any trip. If the a/f is too rich or too lean for the EEC to adapt to, then it will throw a code.
jivepepper
776
Dec 20, 2006
#10
  • Dec 20, 2006
  • #10
Thats what I'm thinking but wanted others opinions.
jstreet0204
939
Winston Salem, NC
Dec 20, 2006
#11
  • Dec 20, 2006
  • #11
Opinions are easy to get. Reasonably thought out answers are the ones to watch for.
I may be wrong, but if I am, I'd like to know the reason why.
cobra killer
2,325
dallas ga
Dec 20, 2006
#12
  • Dec 20, 2006
  • #12
More then likely it will be lean and have some idle/drive issuses. Other than that,if you can deal with the driveability glitches you'll be fine. You could also have your tuner send a file to help with it some until it gets tuned.
Tim
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Dec 20, 2006
#13
  • Dec 20, 2006
  • #13
it *should* be fine. at part throttle, the ecu will still be able to throw enough fuel into the mix to keep everything good. Just dont go WOT, the ECU might not be able to compensate for the difference in airflow at full throttle as compared to part.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Dec 20, 2006
#14
  • Dec 20, 2006
  • #14
Yeah you will be fine, especially on that LSA which will help the idle. jstreet is correct, your MAF will still know how much air is entering the motor. Sure WOT and idle are going to be a little rough just dont go WOT. But you are not going to hurt anything. WOT is where the majority of your tuning will be anyway, so just take it easy and you'll be fine.
When I was putting together the 396 in my 97 Camaro drag car two years ago, I had a 256/267@.050" solid roller camshaft that we had just put in. I drove all the way from New Braunfels, TX to Houston, TX (about a two hour drive) and I had absolutely no problems.
I am assuming you have already checked piston to valve/cylinder head clearance?
jivepepper
776
Dec 20, 2006
#15
  • Dec 20, 2006
  • #15
Tim
Thanks I'm sure if anyone would know it would be you. Unfortunitly I still use a single program sct chip so I can't download a file.
I haven't actually ordered the cams. I want them but I was debating between the cams and the P-51 intake. If I can make it to my tuners then I would prefer the cams. I hope that the piston clearance will be fine I have notched pistons. I plan on ordering them in the beginning of Jan.
M
MBDiagMan
171
Lamar County, Texas
Dec 21, 2006
#16
  • Dec 21, 2006
  • #16
Just keep your foot out of the throttle during the trip to ENSURE that you do not go into open loop operation. In closed loop(cruising) operation, everything will automatically compensate.
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
