Cam Help! 408w
Ok guys, im in the process of building my new 408w stroker. I need some help on the selection of my cam. Ill try to give as much info about my motor and car as i can, thanks. Its a 351w bored .040 over and stroked to 408. All forged internals, AFR 205cc heads with 2.080 intake and 1.6 exhaust. Victor Jr intake, 750 barry grant carb. 1 3/4 bb long tube headers, will be an automatic with a 2500 stall. The heads has a maximum lift of .650. This car will be a street/strip. I wont be going to the track everyday, but i want a awesome street car. My friend has a .550/.550 cam in his 331 stroker, i know i want more lift than he has, i heard the more cubes you have the more it tames the cam down. Anys someone told me to run the comp cams: 236/242/.579/.584/110+4 and that ws with 1.7 rockers. What do yall think about that cam, you think that would be waht im lookin for? Thanks everyones for ya help. Here are some pics of my motor in process. https://home.comcast.net/~chromdoutdubs/final/
-AJ Newman
About all I think I can really offer is my cam specs and what I think about it.
I have a custom grind from comp cams
Duration @ .050
230 / 236
Lift @ lobe
.321 / .329
Lift w/ 1.6RR
.513 / .526
LSA
112
with 4 degrees of advance ground in.
This is a pretty mild cam in my opinion. On a 302 might be pretty decent.
I am working on a larger cam as a replacement, but have had other emergencies come up in the mean time.
I plan to run around .600 lift and get the duration into the 240s
If you have to pass emissions I suggest keeping the overlap to a minimum.
jason
I really have no idea anything about cams, i dont know what duration and all that junk does. I think overlap is when both valves open, and no i dont have to pass inspections, i live in FL and we dont do that here. And the cam specs that guy sent me from comp cams, what format is it in, like what does each of those numbers mean. Also my heads say maximum lift of .650, is that before multiply the rocker ratios? Thanks everyone!
-AJ Newman
-AJ Newman
The .650" max lift stated on the heads is most likely valve lift. Basically you will multiply the lift of the cam lobe by the rocker ratio to get the valve lift. If you are limited to a valve lift of .650, then divide .650 by your rocker ratio (usually either 1.6 or 1.7) to find the max lift that you can run on the cam.
If 1.6 rockers then cam lift should be less than .406"
If 1.7 rockers then cam lift should be less than .382"
Any more lift than this and you will run the risk of the valve spring bottoming out. This would be pretty bad because you would essentially have no control over the valve at that point.
236/242 - This is the duration @ .050" of lift. Because initial ramp rates can vary cam companies list their duration at .050" of lift so that it is easier to compare cam specs. It is also common to find a duration spec at .006" of lift. This is normally called total/overall duration.
.579/.584 - This most likely is the gross lift at the valve. It is well below the .650 that you are limited to by the springs in the heads. You may still have issues with piston to valve clearance so you need to check that any time a new cam is installed.
110+4 - The 110 is the Lobe Separation Angle. The LSA is the angle between the intake and exhaust valves. There are numerous factors in selecting an lsa, and I would not know where to start.
The +4 is probably a ground in advance on the cam.
Here are a few links I saved for cam research.
You will probably learn more from reading these than I can pass on to you.
http://www.hotrod.com/techarticles/18218/index.html
http://www.hotrod.com/techarticles/113_9804_cam/index.html
http://www.hotrod.com/techarticles/113_0209_cam/index.html
http://www.hotrod.com/techarticles/49598/index.html
If you have more questions come on back. The best way to pick a good cam is to learn as much as possible about cam design and cam characteristics.
jason
Thanks for the info man, im gonna go ready up on some of those links you listed. Is there any way to know what my piston to valve clearnace will be before i buy everything. Because i would hate to buy a cam and then find out that it will not. I already have my pistons and heads so i will have to work around that. Thanks.
-AJ
-AJ
Really there is no way to know piston to valve clearance before a cam purchase.
What I have done though is measure current piston to valve clearance with the current cam I am using. I can use the clearance that I have now as a guide in selecting a bigger cam. There are some complicating issues with duration and LSA moving the peak lift points around in relation to the piston though.
Are you completely confused yet :crazy:
If not I'll keep trying :D
jason
so its a hit and miss thing? I have to spend the money on something i have no clue will work or not? I do have notches in my piston, but im not sure if they are deep enough or w/e. Im sure there has to be some mathematical equation for it somehow, id rather not waste the money if i dont have too, EVERYTHING has to be so difficult doesnt it, lol. You already confused me, so dont worry. Thanks
-AJ
I tried to do some math and find the piston valve clearance. The factors are numerous, and the timing of when the valve hits full open will not coincide with when the piston will hit TDC. There would be many angles to account for in this mathemetical model. I am sure it could be done, but I have never seen a calculator for this.
There are many people out there who can guess-timate your p/v clearance, but they do this solely on experience.
If you provide details like what pistons you have (manufacturer and part number), what heads, and what valve size someone here may be able to offer some advice.
Then again you may want to call up the manufacturer of the pistons and ask their advice. Also, other sources for advice may be cam manufacturers and your head manufacturer. None of these companies will have the 100% correct answer, but pooling info from all these sources should give some idea of a upper limit.
Ok well, i hope some p/v clearance experts are out there and see this, here are my specs. Im running Probe pistons dished +19.3cc. Im not sure on that product number on that, it came with my stroker kit, forge alum. Heada are 205cc AFR with 2.080 intake and 1.6 exhaust. Stroke of the engine is 4.00. Im just tryin to find out what is the maximum lift i can go before i run into problems. Hey "vristang" you think that cam recommendation is a good one that the guy from comp cams gave me then? Thanks for the help!
-AJ Newman
ChromdOutDubs said:
So i would take (.579*1.7)=.984
(.584*1.7)=.992
kinda confused :bang: , and also why do they grind advance into the cam? Thanks
If your trying to find lobe lift,your backwards
.579"/1.7=.341" and .584"/1.7=.434" (rounded up to nearest thousanth)
They grind advance in (or possably retard) in order to change the power band around,with out adjsuting the LCA and and valve timing points.Basicly its easier,and normally with the cam built in advance,you dont have to dial in any with your indexed timing chain (if you have one).
