ChromdOutDubs said:
I really have no idea anything about cams, i dont know what duration and all that junk does. I think overlap is when both valves open, and no i dont have to pass inspections, i live in FL and we dont do that here. And the cam specs that guy sent me from comp cams, what format is it in, like what does each of those numbers mean. Also my heads say maximum lift of .650, is that before multiply the rocker ratios? Thanks everyone!
-AJ Newman
The .650" max lift stated on the heads is most likely valve lift. Basically you will multiply the lift of the cam lobe by the rocker ratio to get the valve lift. If you are limited to a valve lift of .650, then divide .650 by your rocker ratio (usually either 1.6 or 1.7) to find the max lift that you can run on the cam.
If 1.6 rockers then cam lift should be less than .406"
If 1.7 rockers then cam lift should be less than .382"
Any more lift than this and you will run the risk of the valve spring bottoming out. This would be pretty bad because you would essentially have no control over the valve at that point.
someone told me to run the comp cams: 236/242/.579/.584/110+4 and that ws with 1.7 rockers.
236/242 - This is the duration @ .050" of lift. Because initial ramp rates can vary cam companies list their duration at .050" of lift so that it is easier to compare cam specs. It is also common to find a duration spec at .006" of lift. This is normally called total/overall duration.
.579/.584 - This most likely is the gross lift at the valve. It is well below the .650 that you are limited to by the springs in the heads. You may still have issues with piston to valve clearance so you need to check that any time a new cam is installed.
110+4 - The 110 is the Lobe Separation Angle. The LSA is the angle between the intake and exhaust valves. There are numerous factors in selecting an lsa, and I would not know where to start.
The +4 is probably a ground in advance on the cam.
Here are a few links I saved for cam research.
You will probably learn more from reading these than I can pass on to you.
http://www.hotrod.com/techarticles/18218/index.html
http://www.hotrod.com/techarticles/113_9804_cam/index.html
http://www.hotrod.com/techarticles/113_0209_cam/index.html
http://www.hotrod.com/techarticles/49598/index.html
If you have more questions come on back. The best way to pick a good cam is to learn as much as possible about cam design and cam characteristics.
jason
