U Uber88GT New Member Dec 9, 2009 117 8 0 Edmonton, Alberta Nov 14, 2010 #1 Nov 14, 2010 #1 Can someone tell me how to figure out the what these numbers mean on this custom grind cam?
Rick 91GT Mustang Master Nov 29, 1999 9,692 95 99 PA Nov 14, 2010 #2 Nov 14, 2010 #2 Ground by COMP, if you call them and give that info or send them the photo they can give you a spec card. It has a 3108 intake lobe and a 3306 exhaust lobe, HR +6 (it is hard to read, but that is the advance it has) According to the master lobe sheets, Here is the basics its .533/.506 215/220
U Uber88GT New Member Dec 9, 2009 117 8 0 Edmonton, Alberta Nov 14, 2010 #3 Nov 14, 2010 #3 Fantastic, thanks! I will send it off to them to see if it will work well with my combo, supposed to be ground for a setup very similar to mine, might be a big step up from the F cam!
