CAM info for a NOOB
  • Thread starter Thread starter 88GTMustang
  • Start date Start date Apr 13, 2004
88GTMustang
247
LA california
Apr 13, 2004
  • Apr 13, 2004
I need help understanding Camshafts, can someone tell me info like What does Duration mean? Lift? RPM RANGE? and So forth! what brands are good also would be a plus! and the best Cam for a GT40P Head?!
BlownStangGT
REPEAT
3,860
Lancaster, PA
Apr 13, 2004
  • Apr 13, 2004
as far as a cam for a gt40 head....Id say check out a trick flow stage one or check out anderson n-21....they are both good cams for that head, I cant help as far as explainining everything, I just know what they mean and can fig them out haha
85GTlover
704
  • Apr 13, 2004
Hey check out www.fordraceing.com I think it is or a site that hooks you up with the Ford parts catologue or on the stangnet top 100 you will find fords site on it are downloads that explain all that you ask. Much easier than someone trying to explain. Hope this helps.
87'GTstang
1,025
  • Apr 14, 2004
duration is in degress (out of 360) for how long the cam keeps the valves open, lift is cam lift X roller rocker ratio and gives you how long you valves are open in inches. If you want a streetable cam, you want a lower duration to have good torque at the bottom end, if you want a track cam then you want a long duration/lift (but idle quality will definitely suffer. When you get a cam with a high rpm range, you have no bottom-end power and all your engine's power is in the high rpm range. Always match you cam to you intake/exhaust setup ect, ect.........
Blue Thunder
1,003
55
68
Upstate New York.
Apr 14, 2004
  • Apr 14, 2004
http://www.themustang-net.com/tech_articles/camshafts.shtml
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
9
Does anyone else have a combo close to this
  • 90Stanger302
  • Dec 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 25, 2025
Qtrhrse23
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Engine HCI Upgrade
  • foxbodyclark
  • Jan 21, 2025
Fox 5.0 Mustang Tech Jan 26, 2025
Mustang5L5
