1993 LX
Doing an HCI swap. GT40X Aluminum Heads/B cam. Stock bottom end with 66,000 miles.
I've had one person tell me to check the forward and aft placement of the cam and to degree it. I've been told that the distributor will take the slack out of the cam and not to mess with forward and aft. I've been told to simply put in the cam at 0 degrees because I'm not messing with the crank and that degreeing the cam can cause valve clearance problems. I've been told to change the "thrust plate" and bolts. I've been told not to hit the cam bearings...
Who's right?
Do I just change the cam out and set it back to 0 and forget it? The guy that told me that builds motors all the time for chevy's and used to own a mechanic shop and race. He told me just set it at 0 and put it in.
Who's right?
I hope not because although the advice you gave is top notch your freaking this guy out. I don't think you will find to many folks on here that got a dizzy gear wiped out by installing a aftermarket cam straight up on even a 200K motor. Degreeing the cam is worth it, although I did not do it, but hey, 9k later an I have no issues.
