Cam lift, duration question
  • Thread starter Thread starter gtcobra302
  • Start date Start date Feb 11, 2006
gtcobra302
118
Centra Florida
Feb 11, 2006
  • Feb 11, 2006
I have a 1989 5 speed GT. It has a trick flow intake manifold, 70 mm throttle body and egr spacer, 73 mm mass air sensor, cold air intake, k and n filter, 24 lb injectors, regulator, 255 lph fuel pump, headers, h pipe, flowmasters, fresh rebuild, flex fan, msd 6al box, cap, rotor, wires and coil, 3.55 gears, mega bit jr lowers, frame connectors, upper and lower front strut bars, zoom clutch, tri axel shifter, aluminum drive shaft. What would be a good street/strip cam? What is a good lift and duration? It doesn't have to be frpp cam.
T
Topdowncruise
207
Canada
Feb 11, 2006
  • Feb 11, 2006
I assume your heads are stock E7's.I would stick with the stock cam if that's the case.If and when you change the heads,match a new (custom) cam to them and the rest of your setup at that time.
gtcobra302
118
Centra Florida
Feb 11, 2006
  • Feb 11, 2006
They are ported and polished gt40 iron heads. Who do you suggest for the cam?
T
Topdowncruise
207
Canada
Feb 11, 2006
  • Feb 11, 2006
I like Comp. Cams.They can advise you on an off the shelf cam or better yet,you could get a custom cam from them and others.My 258 custom grind works really well for street use.It has .510 lift with 1.7 rr's ,206/212 duration@.050 and has 114 LSA.I don't take my car to the strip/race.A 264 or 270 might be better for strip purposes due to their additional duration.Lift of .512 or so would probably help.Make sure you know what result you want and do your homework and if in doubt most experts advise to go smaller.I actually put in a 264 then took it out.Most people on this Forum seem to like the rougher idle and cammed sound but I don't probably because I am old.
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
V
pushrod 5.0 (MILD/ Torque) turbo build for an old scout II help
  • vz58
  • Apr 21, 2024
  • Other Auto Tech
2K
Other Auto Tech Jan 21, 2026
Flyboy60
F
