Cam lift, duration question
I have a 1989 5 speed GT. It has a trick flow intake manifold, 70 mm throttle body and egr spacer, 73 mm mass air sensor, cold air intake, k and n filter, 24 lb injectors, regulator, 255 lph fuel pump, headers, h pipe, flowmasters, fresh rebuild, flex fan, msd 6al box, cap, rotor, wires and coil, 3.55 gears, mega bit jr lowers, frame connectors, upper and lower front strut bars, zoom clutch, tri axel shifter, aluminum drive shaft. What would be a good street/strip cam? What is a good lift and duration? It doesn't have to be frpp cam.
I like Comp. Cams.They can advise you on an off the shelf cam or better yet,you could get a custom cam from them and others.My 258 custom grind works really well for street use.It has .510 lift with 1.7 rr's ,206/212 [email protected] and has 114 LSA.I don't take my car to the strip/race.A 264 or 270 might be better for strip purposes due to their additional duration.Lift of .512 or so would probably help.Make sure you know what result you want and do your homework and if in doubt most experts advise to go smaller.I actually put in a 264 then took it out.Most people on this Forum seem to like the rougher idle and cammed sound but I don't probably because I am old.
