Cam?
  • Thread starter Thread starter Black Sun 5.0
  • Start date Start date May 15, 2004
Black Sun 5.0
1,337
L.I., N.Y.
May 15, 2004
  • May 15, 2004
I'm looking to throw a new 302 with forged pistons in my '91 that will eventually also get a supercharger. I'm going to have my windsor jr's ported and polished along with the lower on the Cobra intake. I'm looking to stay emissions legal, and was wondering which cam might be best for my setup. I was looking at the Steeda cams, but I don't know if they'll pass emissions.
M
Matts89LX5.0
1,314
Long Island, NY
May 15, 2004
  • May 15, 2004
if you're looking at staying emissions legal then an E303 cam. If not get a custom. With my Windsor Jr's and GT40 upper/lower I had a comp cam with a .530 lift. Ran strong.
Matt
04sleeper
2,674
14
89
Dallas, TX
May 15, 2004
  • May 15, 2004
What kind of block are you going to get? What kind of Supercharger?
Black Sun 5.0
1,337
L.I., N.Y.
May 15, 2004
  • May 15, 2004
New 302 with an SC-Trim.
04sleeper
2,674
14
89
Dallas, TX
May 15, 2004
  • May 15, 2004
Unless you are going to get an SVO block or something like that I wouldn't run cam. An SC-Trim supercharger will provide enough boost to push a stock block to it's limit. Let the blower do the work. Unless you like the way a cam sounds.
Black Sun 5.0
1,337
L.I., N.Y.
May 16, 2004
  • May 16, 2004
No cam, eh. I don't mean to sound disrespectful but, no cam? C'mon, I was looking for serious answers here. I've been driving this car too long and on this board enough to know that there are better opinions here. So, anyone else wanna give it a shot? Thanks for the professionalism.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
May 16, 2004
  • May 16, 2004
I would have suggested either the stock cam or a custom - I think 89 sleeper makes a good point, especially since you're trying to keep it emissions legal. Let the manifold/heads/boost do the work. If you insist on a different cam, I'd work with one of the custom designers and be sure they know you're seeking emissions legality. While the cam they supply probably won't have a CARB number, they can help you come up with something that will pass the sniffer test. I don't think the E cam is a good choice at all. It's set up for emissions legality in a naturally aspirated application, not a boosted one. Boosted set ups usually prefer less overlap (more like the stock cam; less like the E cam), and anything you can do to help the exhaust get out of the engine will help. The intake side usually doesn't need help since you're blasting the charge in under pressure. So an exhaust biased cam without much overlap should is what I'd look for. Check out the CompCams XE264. But first choice is custom.
04sleeper
2,674
14
89
Dallas, TX
May 16, 2004
  • May 16, 2004
Yes Michael Yount was correct by quoting me saying "no cam". (Meaning run the stock cam.) I figured I would give you an option that would be able to keep emissions legal very easily. I have a lot of friends that run Real Street and have cars that make between 600-650 RWHP with a stock cam Novi 2000 setup. But they run SVO blocks. Unless you are looking for the sound, or if you just have to have a diffrent cam than stock then a custom cam would be the second best choice.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
May 16, 2004
  • May 16, 2004
BlackSun - so, if you can have more than enough power to absolutely split the stock block down the middle, and you can have it with near-stock idle quality/emissions -- why bother with a different cam?
Black Sun 5.0
1,337
L.I., N.Y.
May 16, 2004
#10
  • May 16, 2004
  • #10
I figured it would be fun to waste my money and crack a brand new block. Anyway, I figured that with 6 lbs of boost and something along the lines of an e-cam would put me in the 400 hp range, so I wasn't all too concerned about splitting the block.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
May 16, 2004
#11
  • May 16, 2004
  • #11
I think you missed the point - but have fun with it; that's the main thing anyway.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
