Cams are done, new dyno #
lvmustanggt
721
Las Vegas
After all the ***** I couldnot get the valve springs change. I towed my car to SLIVER STATE MOTORSPORT to have my cams install. Cost me 160$ to tow my car and $1200 for cams and valve springs install. For all of you don't know me I now have Comp Cam xe270ah-13 and Comp cam Beehive valve springs. I got my car tuesday and today I took it back to the same shop to have dyno tune.
They just start SCT so they didn't have any file for my SCT X2 SF so he just ran on dyno and tune it with the tune that I had on my SCT out the box.
After he played with my SCT and 5 dyno pull I got 291.12rwhp and 301.87 torque. I am happy with the number as I have only few bolt on's. I was hopeing for 300rwhp but didn't happen. I will try to make video this sunday so you guys can hear my car lomp lomp :D
Going to track tomorrow, let's see if I can drive my car to low 13sec. I don't think I will do good tomorrow cause I have no tread left on my nitto 555r.
Thanks for all the guys and girls who try to help me when I was in deep trouble.
291.12RWHP 301.87 Torque :hail2: :hail2: :hail2:
Dope 97GT said:
nice numbers and some LT's may be able to put you over 300
and update your sig with the numbers but how did you lose torque
on stangsource some one said " with bigger cams lose torque for hp"
I lose 6 torque for 25rwhp , I think sound alone or a cams worth 6 torque losee
:D
My engine rocks way too much , should I go higher rpm ? stock rpm was 720rpm so I bump up to 760 but still lot's of engine movement so I was thinking maby I should go 820rpm. What you guys think?
04gtdrop said:
1st congrats on getting your cams done! :nice:
2nd do you lose any MPG when you put in cams? :shrug:
3rd what did you use to clean your engine? and how long did that take you? :shock:
1st thank you
2nd don't know yet
3rd I bought engine degreaser from autozone. Just clean your engine and spray it that's it. Took me maby 10 minuts
:D
My idle is set to 750 with the same cams,no problem. It'll always run rough cause of the duration of the cams,should smooth out at 1000 or higher.
