I got my cam put in last night, and aligned it so the key on the crank and the dowl pin on the cam (also the dot on the cam sprocket) were facing each other. (cam dowl pin and dot on cam sprocket facing down.) When degreeing it this morning it appears that at TDC (intake stroke) the dowel pin on the cam along with the dot on the sprocket is actually facing straight up instead of straight down. So the cam is oriented 180 from what I understood it should be. This is OK, isn't it? If its 180 degrees like this the piston is in the same place. I degreed it like this and everything checked out, so I'm ready to proceed as soon as I get some feedback, thanks.
