Can a turbo-wastegate be used on a supercharged car?
I am wanting to bleed off boost at high rpm's....the goal is to use a small pulley, get boost soon, like 8psi @ 3500rpm, then bleed off anything above that all the way up to 6000rpm....can i use a turbo-wastegate to do this by mounting it on the supercharger discharge tube..instead of the exhaust like on a turbo...and just vent the excess boost to the atmosphere....off course ill use a blow through maf....has anyone tried this or heard of doing it??
RydeOn said:
Ummm, no lol. The wastegate sits on the exhaust side of the turbo.
Not only would it make you run super rich, but inorder to get very early boost, you'll need a pretty small pulley, which will probably overspin your blower. If you want boost much quicker, get a Kenne Bell, or small turbo.
