Can I get 12s?
95.0Stang
538
Kansas
I am getting ready to pick up a 88 GT 5spd, what do I need to get 12s? Will this combo work? I can't afford to do all the bolt-ons, and heads/cam/intake, so I am thinking about doing the H/C/I after all the support components are in place. Then do H/C/I after my fiance gets her new boobies!!!
Pro-M 75mm MAF w/24lb/h injectors
K&N CAI
65mm T-Body
TrickFlow Street Heat Intake
1.7 Cobra RR
BBK Equal Length Headers
O/R X-Pipe
Flowmaster Catback
UCA and LCA
Bilstein Shocks/Struts
Eibach Springs
Aluminum Drive Shaft
3.73 Gears
Pro 5.0 Power Tower Shifter.
if you are a good driver, go on a day where the air is just right, track elevation isn't too high, lighten the car up some, have a good tune and run some slicks, it should be close.
look at my times. i've been practicing quite a bit though. air was also decent that day along with being pretty close to sea level.
If you want to see 12's, all you need is some slicks, gears and a decent shot of giggle gas, maby lighten the car up some.
If you want a 12 second car all the time, your going to need some suspension and H/C/I and all supporting components.
