CAN'T IDENTIFY REAR END
ZILLA
Florida
I have a Ford 8.8.
The casting numbers on the rear diff are F0ZW-AAD.
The tag reads:
S207C X
L08 88 5C29
But the brake mounts read
COBRA RH
COBRA LH
And appear to be factory installed. Is this possible? Limited slip 308 Cobra rear end cast in 1990?
Does that even exist? Go 15741923642974699995117564674572.webp 15741923908642447113606420582071.webp 15741924105366823790893018115476.webp 1574192443717535791339099380203.webp
I think I may have just found the answer to my questions. I found this on LMR's website. I'm pretty sure this came out of a manual transmission 94 to 98 mustang and then somebody swapped out the Cobra supports to facilitate their choices brakes. Any confirmation (or correction) of that would be appreciated.
The differential HOUSING was originally engineered for 1990 Mustang. The housing is for an 8.8 it and was used until a major revision was required.
Date on the tag is from 1995.
S207C = axle code (S = Sterling axle plant)
3L08 = 3.08:1 axle ratio, Traction-Lok differential
88 = 8.8" ring gear
5C29 = axle assembly built on March 29, 1995
  • Informative
Reactions: General karthief
88 = 8.8" ring gear
Thanks
