Ok after doing a search, I was unable to find any solutions to the problem I'm having.
My car usually dies at a redlight idling about once a week - today it did it twice. Also about once a week right after I start it and put it in reverse and give it gas, the RPMs will drop real low acting like it wants to die and then surge back up. About every third time the car will die instead of surging back up. I smell rich gas fumes when it starts again.
The symptoms are this: I will be sitting at a stoplight and the car is idling rock steady at about 650rpm and all of a sudden it is like someone turns the key off - no bucking at all, it just dies. I can put the car in neutral (autotragic) and it cranks right back up with no problems.
I have on new o2s, no vaccum leaks that I can find, new PCV/screen/grommet, timing is set at 14* (running 93 octane), no CE light or codes, new plugs (gapped at .054), wires, cap rotor, air filter, fuel filter, new MSD coil, new ECT and IAT (sensor in intake tract). Just cleaned MAF and IAC. Even put in fresh, new halogen fluid!!! Car has 119k miles on it.
Any ideas what to check next?
