Here's the laundry list of what I've changed/cleaned:
IAC (did this tonite)
ECT (in intake)
ACT (in intake tract)
New O2s
Cleaned air filter (cleaned MAF a couple of weeks after reoiling)
New Fuel Filter
New Distributor
New Coil
New Plugs (at .054)
New 9mm Ford Racing wires
MSD Cap/Rotor
Fuel Pump (added gauge too see above post)
Cleaned MAF
Cleaned T/B
New PCV Valve/Filter/Grommet
Good grounds
New negative cable
No vacuum leaks
Timing rechecked tonite - at 13-14
No codes last time I checked (2wks ago)
98% of the time it idles great. Rock steady. Love it.
Then there's that 2% where (almost ALWAYS when warm) I start it and put it in gear and the RPMs go up to about 1000 and down to about 450ish and unless I give it a touch of gas it dies. It will also occasionally die at a stoplight just like someone turned the key off. After dying it *always* cranks right back up with no problems.
